Losi Mini 8ight ESC & Motor Thread
#751
I swapped in the 0808 5300 about a month ago. running the stock ESC on a 2300 2s. I swapped the spur down to a 60 tooth and the car still loves to wheelie all the time. I am very pleased with the 5300 on 2s and quite impressed at the torque. it isnt so fast that it is uncontrollable like the stock motor on 3s which I was also running but it is still way faster than stock and doesnt cog at all now like the stock motor did.
If you guys want the pic I can post it up
#752
i'd love to see pics. dumb question, but i'm new to this mini do bear with me. does the stock spur fit the 0808? if not, what does?
i'm intrigued by the $8 outrunner but unsure on the ESC and batteries required. i have a ton of 2S batteries that i'd hate to not use. not sure if the outrunner would require 3S or better to be effective or not.
I got the 0808 for 40 bucks and it is a great little motor on 2s and yes it can be run with the stock gears. I just changed out the spur because mine got all chewed up from pebbles.
its like 6 bucks from losi and you get a 3 pack of different spurs.
here are 2 pics of it. nothing fancy done to it but as you can see the motor fits nicely.
#754
thx for the pics! what a great fit. i took the plunge and bought the mini mamba / 5300kv package off the bay today. i really only needed a new esc but what the heck. let's play! i also bought the $8 outrunner and will try it with my sidewinder 3 out of one of my trucks and see which i prefer. i'd also like to buy a 3S battery or two just for kicks but can never find one that fits in stock.
i love this little buggy!!!
#756
you will love that package with the mamba and 0808.
#760
^yep. The user just has to be aware of the spinning outer can and route wires and triple check chassis clearance before running but they will work nicely with the proper esc for the added poles and the esc switching rpm limit.
#763
I run the Micro Pro, not sure if it gives the motor the full potential or not. I just run on a small track and it works fine so far. I run 3s and it is about perfect, slower than stock on 3s but faster than stock on 2s. Hope that helps. I haven't messed with any settings on the esc yet, but may do that soon (punch control and such).
#764
exactly the info i was looking for. keep me (us) posted when you get around to playing with your ESC settings. i'm not looking to go 60+mph. i just want a nice, light package that runs cool and requires driving skill to keep it on four wheels. i like going a little overkill on power, but way too much power in a car this size just doesn't seem like much fun to me. i hope my new setup shows up tomorrow!
thanks for your response
#765
outrunner motors will not work on cars, they are designed for heli's and planes. the outside case of the motor actually turns with the shaft.
