2012 Micro Off Road & On Road Nationals
#16
Hmm...
very disappointing...
the title says Micro ... but you are all talking about 1/18 scale...
That is not Micro
That is Mini...
I know where talkin semantix here... but
I have 2 badd azz 1/24 scale (Micro) rally cars I thought I might be able to race in a real race... but no... i would have to use my Rc18r's..
End
That is not Micro
That is Mini...
End
#17
Hmm...
That is not Micro
That is Mini...
End
That is not Micro
That is Mini...
End
#18
2012 Micro Nationals
Here are the rules for the Stock SC Class
2wd Stock SC
Electronics:
Open to all servos, brushless speed controls, Transmitters/Receivers (the use of a 2.4GHZ Radio System is strongly encouraged).
Battery:
6 cell NiMH Style Battery Packs or 2-Cell LiPo or LiFe Type Battery Packs Only.
Motor:
17.5 Brushless Motors
Tires:
Any Short Course Specific Tires. No fabricated tires
Body:
Full fender short course inspired bodies only.
Chassis/Suspension:
Open to any and all option parts intended for the use on SC vehicles. ROAR wheel base and track width apply.
Speed Controls:
All speed controls must be run in no timing/no boost profile. Speed controls that cannot be checked are not allowed. Anyone caught cheating will be disqualified from said class and no refund will be given.
NOTE:
Other vehicles conforming to the above mentioned rules and specs may be allowed pending race director’s approval.
2wd Stock SC
Electronics:
Battery:
Motor:
Tires:
Body:
Chassis/Suspension:
Speed Controls:
NOTE:
#19
nats
Roll Call??????
#21
Rules and other race information would be great.
#22
Here are the rules for this year, just about the same as last year. Chris will have a class if there is enough to run it. The minimum for a class should be around 6 entries. Anything less than that he will decide on it.
The stock motors this year will be the Ammo 2650 from the ECC.
Off Road Classes
1/18th 4wd Truck Stock
CHASSIS: 1/18 Plastic 4WD Chassis
WHEELBASE: 166mm Max
WIDTH: 184mm Max
MOTOR: Handout Motor
TIRES: 1/18 Rubber Tires ONLY, No touring car tires, No Hex Adapters
ELECTRONICS: 0 degrees of timing
BATTERY: 2 Cell LiPo or 6 Cell max 2/3A Type Battery Packs ONLY (7.4 volts max)
BODY: Must use a stadium style truck body, wings must be attached to the body (No Truggy Style wings)
1/18th 4wd Truck Open
CHASSIS: 1/18 4WD Chassis
WIDTH: 184mm Max
MOTOR: Open Brushed or Brushless Micro Motor
TIRES: Open 1/18 rubber or foam Tires. No Touring Car Tires, No Hex Adapters
ELECTRONICS: Open Electronics
BATTERY: Open battery voltage; Li-Po or 2/3A Cells
BODY: Must use a stadium style truck body, Truggy type wings are allowed
1/18th 4wd Buggy Open
WIDTH: 184mm Max
TIRES: Open 1/18 rubber tires. No Touring Car Tires, No Hex Adapters
Must run narrow front tires, (similar to the Front RC18B or Duratrax Vendetta)
Front tires must be less than 1” wide when mounted on rims (No wide front tires/rims)
BODY: Must run a buggy body with wing
1/18 Short Course Open
WHEELBASE: 187mm Max
WIDTH: 170mm Max
TIRES: Rubber short course style tires only
ELECTRONICS: Open Micro Specific Electronics
BODY: Short Course style body only that covers the rims and tires
1/18 2wd Open (Truck or Buggy)
Open 2wd 1/18 chassis
Open brushed or brushless motor
Open 1/18 Tires including foams. No touring car tires, no aftermarket hex adapters
WIDTH: 184mm Max
Open Electronics
Li-Po or 2/3A Cells
Must use a stadium style truck body, baja body, buggy body, truggy wings are allowed
1/16th 4wd Open (Truck or Buggy)
CHASSIS: Open 4WD Chassis
WHEELBASE: 190mm Max
WIDTH: 220mm Max
TIRES: Open rubber tires (1/10 hex adapters & tires are allowed)
Mini Monster Open
Open chassis
Open motor(s) not to exceed 2 – 400 in size. Brushed or brushless
No foam tire or 1/10 touring style rims - Rubber tires only
Tires must be at least 2 ˝” (63mm) tall when mounted on rims
Open electronics
Li-Po or 2/3A Cells
Must use a mini monster type truck body, stadium truck body or baja body, truggy wings allowed
On Road Classes:
1/18th Stock Touring (4wd)
CHASSIS: 1/18th 4WD Touring Car Chassis
WHEELBASE: 163mm Max
WIDTH: 115mm Max
TIRES: Scale Foam or Rubber Tires
ELECTRONICS: 0 degrees of timing Only
BATTERIES: 2 Cell LiPo or 2/3A NiMh Cells (7.4 volts max)
BODY: Open 2 or 4 Door 1/18 Touring Car/Sedan Style Bodies (chassis and tires must fit inside the body)
1/18th Open Touring (4wd)
WIDTH: 115mm Max
MOTOR: Open Brushed or Brushless Micro Motor (380 sized or smaller)
Open Rally Class
Open Chassis
Dimensions (147mm wide, and 166mm wheelbase max)
Team Associated or Duratrax rubber or foam rally tires/rims only
Open electronics
Li-Po or 2/3A Cells
Bodies allowed include the Associated Rally bodies, Duratrax rally bodies, the Exotek body and the RJ Speed bodies
Factory wings only
1/18th Stock Pan Car (2wd)
CHASSIS: 2wd Direct Drive Pan Car Chassis
WHEELBASE: 150mm Max
WIDTH: 120mm Max
MOTOR: Handout
TIRES: Foam Tires Only
ELECTRONICS: ESC with 0 degrees of timing in Blinky Mode
BATTERIES: 4 Cell 2/3A NiMh Cells 4.8 volts or 7.4v Lipo is allowed
BODY: Open 1/18 Pan Car Body. Side and flat rear wings are NOT allowed
1/18th Pan Car Open (2wd)
WIDTH: 120mm Max
TIRES: Foam Tires only
BODY: Open 1/18 Pan Car Body. Side and flat rear wings are allowed (any part of a side or rear wing can extend a maximum of 18mm above any part of the body, therefore a side wing must follow the profile shape of the body) Side wings will also have a maximum of 115mm in length.
1/14th & 1/16 On Road Open (4WD)
CHASSIS: 1/14th/ 1/16 4WD Chassis
WIDTH: 140mm Max
MOTOR: Open Brushed or Brushless Micro Motor (440 sized or smaller)
TIRES: Open 1/14 rubber or foam tires
BODY: Touring car/sedan style 1/14 body
1/18 Truck/Buggy Flat Track Open (2wd or 4wd)
CHASSIS: 1/18 4WD or 2WD Chassis
WIDTH: 184mm Max
TIRES: Open 1/18 Tires including foams. No Touring Car Foam Tires, No 1/10 Hex Adapters
BODY: Must use a stadium style 1/18 truck body or off road buggy
Misc……
These rules were made to accommodate the majority of hobby shop grade 1/18 vehicles on the market.
• Assume the following: If the rules don’t say you can do it, you can’t. ASK FIRST
• NO REVERSE. If you use reverse, even once, you will be assessed 5 second stop & go penalty. After 3 stop & go penalties in one race you will be disqualified from that race and your car will be removed from the track. No refund will be given.
• No rough or “team” driving. Anyone who is considered to be team driving or rough driving will be disqualified and no refund will be given.
• All races will be 5 minutes long (excluding the Super Main)
• 2/3A cells or 2S max for LiPo type battery packs for stock classes
• No Sub C sized cells in ANY class
• No 540 Sized motors in any class
• Tires may not extend beyond the wheel wells in the micro touring car classes.
• Unless given prior approval, vehicles can ONLY race in classes originally intended by the manufacturer.
o It is acceptable to turn an X-Ray M18T Pro into an M18B (for the buggy open class) or an M18MT
o The Vendetta ST can run in the buggy open class provided it has a buggy body and buggy tires/rims and fits the provided dimensions
• All prototype and one of a kind items/modifications must be approved by the race director before being used in competition. Long-term prototype vehicles admitted at race directors approval
Off Road Classes
WIDTH: 184mm Max
WIDTH: 184mm Max
WIDTH: 184mm Max
WIDTH: 170mm Max
WIDTH: 184mm Max
Open Electronics
Li-Po or 2/3A Cells
WIDTH: 220mm Max
Mini Monster Open
Open chassis
Open electronics
Li-Po or 2/3A Cells
On Road Classes:
WIDTH: 115mm Max
WIDTH: 115mm Max
Open Rally Class
Open Chassis
Open electronics
Li-Po or 2/3A Cells
Factory wings only
WIDTH: 120mm Max
MOTOR: Handout
WIDTH: 120mm Max
WIDTH: 140mm Max
WIDTH: 184mm Max
Misc……
#23
What about the slash and the Losi mini sct? will thise be running in the open 14th/16th scale truck buggy class?
#24
As of right now I will be running 10th scale 17.5 and I will also be running my Losi Mini SCT.
#25
Is there any word on if there will be a Micro Off Road/On Road Nats for 2013?
#28
Is there any possibility there will be a class for 1/14 tacon buggys and 4wd mini 8 type buggys?
#29
#30
Any news??
