Mini Late model setup
Looking for some advice on setups regarding losis mini late model. i have a dynamite fuze brushless system with a 2c lipo. im racing on a dirt medium bank track that more than likely will be blue grooved...any help is greatly appreciated thanks, larsotra
I have only run mine on carpet. But if the track blue grooves it should have good traction. I have an gold (super hard) Associated VCS spring on my right front shock. Stock springs on all other shocks. 50 weight all around. the left side shocks moved in at the bottom and the right side moved out. Battery on left and back as far as possible. An once of lead on left rear of chassis. Graphite and aluminum steering links. Adjustable tie rods. Also have small rubber bands on all tie rods and links. Top wing low in front and all the way forward on dirt that might not work as well.
