Brown Engineering - Conversions >
Old 12-27-2012 | 08:35 PM
  #31
bigb11's Avatar
HERE IS THE NEW BODY
Attached Thumbnails Brown Engineering - Conversions-or18-front.jpg   Brown Engineering - Conversions-or18-side.jpg
bigb11 is offline
Old 12-27-2012 | 09:23 PM
  #32
rustlererad3's Avatar
i love this thing what scale is this bad girl
rustlererad3 is offline
Old 12-27-2012 | 11:34 PM
  #33
bigb11's Avatar
1/18TH SCALE
bigb11 is offline
Old 01-04-2013 | 08:01 PM
  #34
protc3's Avatar
Car looks sick bro. Cant wait to give it a run
protc3 is offline
Old 01-04-2013 | 10:52 PM
  #35
I want to have one of these
Old 01-05-2013 | 03:45 AM
  #36
protc3's Avatar
Part i like most is a double wishbone front end on such a tiny car. This car a 10 steps ahead of everything else i have seen. That is one advanced little car. Kudos Marvet.
protc3 is offline
Old 03-04-2013 | 10:08 PM
  #37
bigb11's Avatar
We have 8 Rhinos in stock.
bigb11 is offline
Old 03-11-2013 | 10:27 PM
  #38
bigb11's Avatar
news about the Rhino.
http://by165w.bay165.mail.live.com/m...264c1ca12&fv=1
bigb11 is offline
Old 03-15-2013 | 07:22 PM
  #39
bigb11's Avatar
Default News!
We will be adding a build option for the rhino an extra $12.50 receive a built kit. Tell us which spur gear you want, 47, 49 or 51.
bigb11 is offline
Old 04-10-2013 | 01:15 PM
  #40
bigb11's Avatar
Default ORDERING FROM WEBSITE
WHEN ORDERING FROM WEBSITE AND USING PAYPAL, IF YOUR SHIPPING IS UNCONFIRMED BY PAYPAL, THE BUYER WILL GET AN EMAIL FROM US ASKING FOR YOUR SHIPPING ADDRESS, ADDRESS MUST MATCH PAYPAL INFORMATION. I WILL EMAIL YOU , IF YOU DO NOT REPLY WE WILL CANCEL YOUR ORDER AND YOU WILL NOT BE ALLOWED TO ORDER FROM US. EVER!
THANK YOU.
bigb11 is offline
Old 04-11-2013 | 09:00 AM
  #41
strodedawg's Avatar
are elctronics, body and tires the only thing needed to complete the kit?
limited edition? are you only making so many of them and stopping?
what electronics do you recommend?
strodedawg is offline
Old 04-11-2013 | 09:17 AM
  #42
bigb11's Avatar
all you need are your electronics, we are only making lots of 15.
castle creation, reedy and novak make systems that will fit our cars. if you use castle you must find early motors because the new 4 pole motors are to long.
bigb11 is offline
Old 06-08-2013 | 07:25 AM
  #43
DaSilva3525's Avatar
Just found out about this killer little machine! Good to see someone still working on the 1/18th platform
DaSilva3525 is offline
Old 03-22-2014 | 06:11 PM
  #44
bigb11's Avatar
We are going to produce 10 oval rhino kits.
bigb11 is offline
Old 03-26-2015 | 07:53 AM
  #45
ptt
Please help with diff problem....
When I tighten the right wheel onto the hub via the threaded axle...the right diff also tightens and eventually locks causing the car to pull right with any torque applied.
Is the solution to not tighten the wheel to the hub and ensure its really loose?
Edit: Even with a loose wheel nut, it still pulling right on acceleration. Uneven diff? If I over tighten the diff and it still pulls, does that rule out the diff causing the pull?
ptt is offline
