xcelorin 1/36 brushless esc problem
hey i have just installed an xcelorin brushless esc and 10250kv motor and a losi 27mhz am 3 wire servo conversion kit in my micro-t and i have set it all up i have steering but when i goto go forwad or reverse it jitters the rear wheels but dosent go when i put load on the wheels the blue led stays a solid blue has anyone else had this problem and can you help me if u have
I can only speculate:
1) The AM controller you are using might have a glitch. Try a different controller. I use a 2.4Ghz from my team losi MRC on my brushless micro T and I don't have that problem.
2) As also mentioned in your youtube link... there could be a simple wire connection problem. Have you tried directly soldering the wire contacts to the motor?!?
