Jr-R1 with mini-z asf module? >
Old 03-23-2009 | 09:41 AM
Lt_scallywag's Avatar
Default Jr-R1 with mini-z asf module?
Does anyone know how to convert the KO 2.4ghz ASF module so it will work with a Jr-R1 radio? Some help would be greatly appreciated.
Lt_scallywag is offline
Old 03-29-2009 | 12:31 PM
bump
Old 03-29-2009 | 06:43 PM
MikeXray's Avatar
I don't think any conversion is needed, that radio is essentially the same as the KO EX-10, it should plug right in.
MikeXray is offline
Old 03-30-2009 | 01:07 PM
Bermbuster's Avatar
i had the R1 and the modules are different between the R1 and the EX10.
Bermbuster is offline
Old 03-30-2009 | 01:13 PM
MikeXray's Avatar
Did you push hard enough?
http://www.horizonhobby.com/Products...ProdID=SPM1013
I can't say for sure, but I was pretty sure the spektrum module transferred since my friend switched from the KO to the R1 and didn't have to buy a new module. Its possible KO did something size wize to make it not fit the R1?
MikeXray is offline
Old 03-30-2009 | 04:54 PM
Bermbuster's Avatar
the module you linked is for a Z-1 not the R-1.....
here is one for the R-1
http://www.horizonhobby.com/Products...ProdID=SPM1001
I hope with all your painting the fumes arent getting to you.....
Old 03-30-2009 | 05:49 PM
MikeXray's Avatar
ok you're right, what the heck is an R-1, the only pic I found looked crazy old
MikeXray is offline
Old 03-30-2009 | 06:16 PM
You're right, it is a pretty old radio but I would hate to get rid of it.
Old 03-31-2009 | 12:00 PM
I would look at the circuit diagram on the bottom of the page.
http://mini-z-guide.com/radio.htm
Use volt meter to check for + and grd. Use oscilloscope to check for the signal pin. If you don't have an oscilloscope, you might want to put the volt meter on lower setting, and detect which pin gave some readout. Once you figure out which pin is what, then rewire the connector inside the module. Chances are it will work.
benmlee is offline
Old 03-31-2009 | 01:47 PM
Bermbuster's Avatar
the module case has a different footprint. You may have to trim the pcb for the module as well....
the best way to make it work would be by making a piggyback cable from the tx to rx and then using velcro to hold the module on....
Old 03-31-2009 | 02:53 PM
Thanks for all your replies. More are welcome.
Old 04-13-2009 | 09:46 PM
To The Top!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!
Old 06-13-2013 | 07:08 AM
Since it is possible to solder the ASF module to Futaba 4PK would it be the same with 4PL and Sanwa MT-4?
Have anyone seen it? Or know of the wires diagram?
quintilio is offline
Old 06-13-2013 | 12:28 PM
J-milz's Avatar
I've seen a 3pk conversion and also a m-11 conversion on the mini z racer forum. You can Frankenstein one, For sure. The question is why? You can get a decent ex-10 or JR z-1 for less than $100. Hll, you can get a ko Mars ex1 for $50. It has the same functions as the r1.
J-milz is offline
