18R Front Spool1
18R Front Spool1
Hi all,
Is anyone running a front spool. Just wanted find out the benefits of running one. I am running stock diffs in car, but wat do you all recommend. Thx
I am planning on runnin parking lot racing soon. So any info would be great.
Mathew
Mathew
The front spool will give the car more on power steering, and less off power steering. overall, it makes the car more stable and driveable. I would definately run one on asphalt. Just be sure to have your diff shimmed perfectly as a solid axle is more abusive to the drivetrain (ie diff gear and input gear)
full locked it will be more stable off power on power is the same but the spool will push slightly versus get loose as soon as you let off
