Mini T Hopups?
Old 04-13-2007, 08:56 PM
Default Mini T Hopups?
Hey whats up. I was wondering if anyone had any good websites where you can get hopups for the Mini T.
Mjk87 is offline
Old 04-17-2007, 01:10 PM
Default I havent found many...
I have been visiting the standard few. There is one called Losipartshouse that looks pretty cool. I have had some luck using parts off of 1/12s. I have a set of Associated VCS shocks I am using for my F and R for instance.
You having any durability issues with your truck?
Mdave is offline
Old 04-17-2007, 01:50 PM
Im having a problem with the stock turnbuckles. The front right turnbuckle keeps bending. Im planning to upgrade to the titanium ones losi offers. Other then that ive only had a few ballcups pop off but thats an easy fix. O and my motor keeps working loose and the pinion gear moves away from the slipper. Im planning to put a new motor mount on when i upgrade the electronics.
Mjk87 is offline
Old 04-17-2007, 02:40 PM
sheetmetal2's Avatar
Default turnbuckles
I've heard some guys say that they use TC3 Turnbuckles and change to the larger balls and ballcups. I wish I would have looked closer into that before I spent the money for the titanium ones that are direct replacements. I will say that they were a great complement to the car.
sheetmetal2 is offline
Old 04-18-2007, 10:14 AM
t9dragon's Avatar
Try www.thetoyz.com
t9dragon is offline
Old 04-24-2007, 08:25 PM
Default Partz
I have been using a set of 18T Steel turnbuckles. It takes a little bir of playing with but it works pretty good.
I think the TC3 with 1/10 ball cups would work better though.
Mdave is offline
