LC racing 1/14 2wd buggy
#32
Suspended
hmm this car has covered spurgear stock? Or not?
You have take off that cover maybe?
I need spurgear cover.
Im thinking order this car, need know for shure it has covered spurgear first.
I have 2different combos
1 60a ESC and 2845 motor 3.17mm shaft 3930kv
2 80a ESC and same motor with 4370kv
Both my Brushless combos handle 3s. They are 800w Motors are both Rocket 2845 size, Waterproof
Both ESC are rebranded HW with programmer 1 is 60a second is 80a Waterproof
programcard.
Motors i did buy last year cheap Blackweek, they are brand new. Paid 13bucks each
ESC i have buy last month at Aliexpress 20-24bucks each.
I will build two cheap 1/14 brushless cars.
Is the driveline strong and everything else? can it handle 3s also?
I need buy some 3.17mm Pinions, what Pitch does this car have?
What pinion sizes should i get to my combos, to this car?
Im looking at 50-55mph top speed. i will have top speed adjusted by radio at about 85%
somewhere 40mph.
And sometimes be able run 100% at about 50-55mph
with foams on the streets.
I plan to order this tomorrow.
Need info about spurgear cover, durability, and Pinions
please. Help
Ooh one more stupid question, what size servo?
Micro or Mini ?
Will this Servo fit?
Micro Servo Waterproof 2.8kg/0.10sec (7.4)
Type: Digital
Bearing: Dual
Motor Type: DC
Gear Type: Metal
operating speed (4.8v): 0.16 sec/60 degrees at no load
operating speed (6.0v): 0.12 sec/60 degrees at no load
operating speed (7.4v): 0.10 sec/60 degrees at no load
stall torque (4.8v): 1.9kg.cm (26.4 oz/in)
stall torque (6.0v): 2.5kg.cm (34.7 oz/in)
stall torque (7.4v): 2.8kg.cm (38.9 oz/in)
potentiometer drive: direct drive
dimensions: 22.5x12.5x24.0 mm /0.89x0.49x0.94 in
edit:
how large lipo fits max in this car?
Can the body take 3s under ?
Max lenght and Wide?
programcard.
somewhere 40mph.
please. Help
Micro or Mini ?
Type: Digital
Bearing: Dual
Motor Type: DC
Gear Type: Metal
edit:
#33
Here is my BHC-1 for the winter 2023
Stock kit with:
aluminum servo arm
aluminum bell cranks
Rear sway bar kit for tuning
eagle aerial shock towers
eagle aerial battery hold down
electronics:
surpass 8.5
HW just stock g3 60a
Batan MG servo
1500 mah 60c lipo
thing runs amazing on carpet.
My needs:
Other options at servo hv preferred, batan works great though
rear tires- either someone who cuts tires can help me or is the a hidden tire somewhere that fits this rim
Cheap way to get into some fast carpet racing
Stock kit with:
aluminum servo arm
electronics:
surpass 8.5
Batan MG servo
1500 mah 60c lipo
My needs:
