Mini-96 World Challenge
#2236
May 2024 Layout
Class ~ Stock
Date ~ 5/07/2024 @ 7:24 pm
Location ~ Santa Rosa, California
Race Time ~ 370.817 Seconds / 6:10.817 Minutes
Fastest Lap ~ 4.458 Seconds
Chassis ~ Kyosho MR03 EVO
Body ~ Jomurema GT1
Wheelbase ~ 98mm
Tires ~ Marka 25 Degree Slick Fronts & Marka 15 Degree Radial Rears
Springs ~ Yellow
Disc Damper~ Nexspeed
T-Plate ~ Generic Carbon 4
Motor ~ 4100 KV Brushless
Motor Pod ~ MR04 Low CG Plastic Pod
Batteries ~ Eneloop Pro 900mah AAA
Gearing ~ 9t Pinion
Notes ~
Class ~ Stock
Body ~ Jomurema GT1
Wheelbase ~ 98mm
Springs ~ Yellow
Gearing ~ 9t Pinion
Notes ~
#2237
May 2024 Layout
Class ~ Pro Stock
Date ~ 5/29/2024 @ 6:49 pm
Race Time ~ 418.438 Seconds / 6:58.438 Minutes
Fastest Lap ~ 4.865 Seconds
Body ~ Jomurema GT1
Wheelbase ~ 98mm
Tires ~ PN KS Slick Fronts & Marka 15 Degree Radial Rears
Springs ~ Yellow
Motor ~ Kyosho Xspeed 5600 KV Brushless
Gearing ~ 9t Pinion
Notes ~
Class ~ Pro Stock
Body ~ Jomurema GT1
Wheelbase ~ 98mm
Springs ~ Yellow
Gearing ~ 9t Pinion
Notes ~
#2238
May 2024 Layout
Class ~ Open 2WD
Date ~ 5/14/2024 @ 9:31 pm
Race Time ~ 402.525 Seconds / 6:42.525 Minutes
Fastest Lap ~ 4.619 Seconds
Chassis ~ GLR-GT
Body ~ Jomurema GT1
Wheelbase ~ 98mm
Springs ~ Red Front, Green Rear
T-Plate ~ N/A
Motor ~ Hobby Wing 3500 kv Brushless
Batteries ~ Tatto LIPO 300mah
Gearing ~ 9t Pinion
Notes ~
Class ~ Open 2WD
Chassis ~ GLR-GT
Body ~ Jomurema GT1
Wheelbase ~ 98mm
T-Plate ~ N/A
Gearing ~ 9t Pinion
Notes ~
#2239
May 2024 Layout
Class ~ Open 4WD
Date ~ 5/14/2024 @ 6:45 pm
Race Time ~ 409.551 Seconds / 6:49.551 Minutes
Fastest Lap ~ 4.809 Seconds
Chassis ~ GLA Giulia
Body ~ Jomurema GT1
Wheelbase ~ 98mm
Tires ~ Marka 25 Slick Fronts & Marka 15 Slick Rears
Springs ~ Blue Front, Purple Rear
T-Plate ~ N/A
Motor ~ Hobby Wing 5000 kv Brushless
Gearing ~ 11t Pinion
Notes ~
Class ~ Open 4WD
Body ~ Jomurema GT1
Wheelbase ~ 98mm
T-Plate ~ N/A
Notes ~
#2240
May 2024 Layout - Unofficial testing Class for MX5 (Miata)
Class ~ MX5 Open Class
Date ~ 5/07/2024 @ 6:49 pm
Race Time ~ 432.277 Seconds / 7:12.277 Minutes
Fastest Lap ~ 4.914 Seconds
Chassis ~ Kyosho MR04 EVO2 / Nexxspeed RM Motor Pod
Body ~ Mazda MX5 (Miata)
Wheelbase ~ 90mm
Tires ~ PN KSM Slick Fronts & Marka 15 Slick Slick Rears
Wheels ~ +1 Offset Narrow Rear and Narrow +1 Fronts Kyosho Wheels
Springs ~ Yellow
Disc Damper ~ Nexspeed
T-Plate ~ Generic Carbon 2
Gearing ~ 10t Pinion
Notes ~
Wheelbase ~ 90mm
Springs ~ Yellow
Notes ~
#2241
Yes the month past a Bit quick for me with family vacations and all so I didn't get to I prove times later in the momth. The f1 is harder to drive cause of the size and front wing but as i started making controller adjustments it got easier but I'll have more runs in June as I prep for my first big mini z event.
#2242
Class- Porsche Cup
Date-05/31/2024
Location- Quebec Canada
Race Time- 6:57
Fastest Lap- 4.595 seconds
Chassis- MR03
Body- Porsche GT1
Wheelbase- 90mm
Wheels/Tires: F- 8.5mm 0mm Kyosho 30 low profile / R- 11mm +1mm Kyosho 20 radial
Motor- PN 70T
Batteries- Gens Ace 750
Front Springs- purple
T-Plate- carbon fiber ?
Motor Mount- stock RM
Dampener (If applicable)-
Gearing- 8t pinion/ stock gear diff
Note:Last minute run, rebuild the Porsche after Frying my asf board
Date-05/31/2024
Race Time- 6:57
Chassis- MR03
Body- Porsche GT1
Wheelbase- 90mm
Motor- PN 70T
#2243
Location-Orlando FL
Race Time- 7min 9 seconds
Fastest Lap-4.96
Chassis-MR-03
Body-McLaren F1
Wheelbase-98mm
Tires-Fronts Kyosho 30, Rears Kyosho 20
Motor-Stock
Batteries-Gens Ace 750s
Front Springs-stock
T-Plate-stock
Motor Mount-Stock MM
Dampener (If applicable)-N/A
Dampener Fluid (If applicable)-N/A
Gearing-stock and 7T pinion
#2244
May 2024 Layout
Class : Open 2WD
Date :5/9/24
Race Time: 8:00.06sec
Fastest Lap:5.23sec
Chassis: GLF1
Body: GLF1
Wheelbase:114mm
Tires: F1 Marka but unsure of specs
Springs: Red
T-Plate: N/A
Motor :GL 2500 kv Brushless
Batteries: Spectrum 2s 300mah 30 mah
Gearing : 13T Pinion
Notes: Had very little time to run and ordered new tires and pinions this month but had not had any time to work on the car nor run. I expect to get it better under control next month. I had to run it under 50% power to get it under control. Looking forward on what i can do with smaller pinions and other changes. Even though this month it was slower than by box stock, I love to drive this car way more.
Class : Open 2WD
Date :5/9/24
Fastest Lap:5.23sec
Chassis: GLF1
Body: GLF1
Wheelbase:114mm
Springs: Red
T-Plate: N/A
#2245
Box Stock
Date 5/11/24
Location- California
Race Time-327.60
Fastest Lap-4.10
Chassis-MR-030 ASF
Body- R8
Wheelbase-98mm
Rear Marka 10
Front PN medium slick
Motor-Stock
T plate white fiberglass
Front springs PN RED
Date 5/11/24
Race Time-327.60
Fastest Lap-4.10
Chassis-MR-030 ASF
Body- R8
Wheelbase-98mm
Rear Marka 10
Motor-Stock
#2249
MX-5
Date-5/27/24
Race Time-333.25
Fastest Lap-4.14
Chassis-MR-03
Body-MX-5
Wheelbase-90mm
Tires- R PN KSK 40. F PN KS medium slick
Motor-3500KV
Batteries- Enloop
Video https://www.youtube.com/watch?v=Bg3SKpqS3no&t=13s
Sorry the sound quality is so bad. Working on it.
Date-5/27/24
Race Time-333.25
Fastest Lap-4.14
Chassis-MR-03
Body-MX-5
Wheelbase-90mm
Motor-3500KV
Batteries- Enloop
#2250
Took a few hours for my hand to calm down and this is what I got with my 90mm Narrow MX5. I had a traction roll about 10 laps to go, and it stopped close by but the body partially came off, but I fixed it best I could quickly. So the last laps were not perfect.
The MX5 on narrows would loose traction at the Throttle D/R of the wide rears, so I had to back it down a bit to calm it. I need to do more tweaking 4 sure!
Class- 90mm Narrow
Date-05/31/2024
Location- Central Texas
Race Time- 6:33.597 / 393.597 seconds
Fastest Lap- 4.773 seconds
Chassis- MR03
Body- MX5
Wheelbase- 90mm
Wheels- F- 0mm N PN BBS Yellow / R- 0mm N PN Wht. Dish Wheel
Tires- F- N PN KS Low Height Slicks Medium / R- N PN KSM Soft
Motor- PN 3500Kv
Batteries- SpeedHouse 800
Front Springs- Purple
T-Plate- Nexx #4
Motor Mount- Nexx 90/94mm RM Black
Dampener (If applicable)- PN DDS Gold top/ Purple bottom springs
Dampener Fluid (If applicable)- dry
Gearing- 12/53
Notes- NB4 Steering D/R 100%, Expo - 22%, Throttle D/R 82%
The MX5 on narrows would loose traction at the Throttle D/R of the wide rears, so I had to back it down a bit to calm it. I need to do more tweaking 4 sure! Class- 90mm Narrow
Date-05/31/2024
Chassis- MR03
Body- MX5
Wheelbase- 90mm
Motor- PN 3500Kv
T-Plate- Nexx #4
Gearing- 12/53
3035Likes
