Mini-96 World Challenge >
Like Tree3035Likes
Old 09-03-2022 | 04:18 PM
  #1501
Originally Posted by TAMAK
I assume same layout, Counter Clockwise.
Which post number has the layout? I am not seeing an image of one for August.
chjosi is offline
Old 09-04-2022 | 04:04 AM
  #1502
It was in post #1489 but I don't see it now. I have a screen shot of it on my phone I can post if no one else can repost.
I tried this layout CCW and I can NOT get it down!!! Man I need to get my glasses fixed! LOL
BoxxerBoyDrew is offline
Old 09-04-2022 | 06:16 AM
  #1503
Here is it
chjosi likes this.
Poor_Boy is offline
Old 09-04-2022 | 10:23 PM
  #1504
Hey Guys,
I am looking at future upgrades to my Mini-Z stuff, and the biggest thing that I have problems with, other than my driving skills, is using the phone type lap counting apps for the challenge. The 2 I have tried work almost flawlessly outside with my Reflex 14th scale, but the room that my track is in is dim and during a 75 lap run they will miss 3 or 4 laps or it will false count a lap or 2. That throws me off trying to make sure I'm driving where the app will read vs. the best line for the course, and I wind up bouncing off the walls!
So I am wondering how accurate are the "EZLap" type IR systems? The only transponder system I have used the wire under the dirt type, and as long as the laptop it was hooked to was working, it was flawless. Are they worth the money, and if so is one brand better for this scale?
Thanks for any help!!! Drew
  #1505
Default Is shaving of front splitter allowed in Box Stock?
Originally Posted by cdog4w
Sad I didn't get to run this month, hopeful for next I also got a DWS to try on my AWD and will try to run it too?
Poor_Boy did you shave the splitter on that mclaren? Is that allowed in box stock? I'm split between wanting to do it on my amg gt3 and using it as a punishing training tool
Hi everyone, I'm new to Mini-Z and RC racing and am looking to join in the races. I have the Mclaren body and am wondering if I can remove the splitters and still remain in box stock class?
AlvBo is offline
Old 09-05-2022 | 01:41 AM
  #1506
Welcome AlvBo! I've only been running Mini-Zs for about 6 months and have learned alot from the Great Guys here!
I have seen pics of others running box stock with splitters ground down/removed, so I would THINK it's ok. But I'm not runnin nothin, so I would get a 4sure answer from the guys in charge before doing any changes!
Get ready for some challenging fun!!! Drew
AlvBo likes this.
Old 09-07-2022 | 12:39 PM
  #1507
abailey21's Avatar
R/C Tech Elite Member
Originally Posted by BoxxerBoyDrew
Hey Guys,
I am looking at future upgrades to my Mini-Z stuff, and the biggest thing that I have problems with, other than my driving skills, is using the phone type lap counting apps for the challenge. The 2 I have tried work almost flawlessly outside with my Reflex 14th scale, but the room that my track is in is dim and during a 75 lap run they will miss 3 or 4 laps or it will false count a lap or 2. That throws me off, and I wind up bouncing off the walls!
Check Kennon hobby, I know they sell the easy lap system. I see a lot of home tracks use it to. I have noticed a lot of guys have the wire rigged with small PVC pipe above the track, the part that is confusing to my is that most look like they're damn near 12" above the track surface.
I'm in the middle of selling a bunch of 8th and 10th stuff and plan on buying myself some RCP and the easy laps system but my wire halo is going to be about 4" above the track.
abailey21 is offline
Old 09-07-2022 | 04:12 PM
  #1508
Thanks abailey21! I am a regular at Kennon, MUCH MORE than my wife would like! I just got my PN disk damper setup installed on my MR03. MAN what a difference it makes over the box stock setup! I had to trim the rear window of my Jomurema body to clear the PN dual spring shock when using the factory MM motor pod( I'm guessing the mounting point for the disk post is different heights between factory and aftermarket motor pods), but no biggie, as it won't be box stock again. I have some other hobby stuff I'm in the process of selling to fund my mini-z, but I doubt I will make enough to fund the laptimer and a new radio, so I'm trying to figure out which is the best buy right now.
Now to go try the different adjustments I now have in the rear end to best suit the track and my driving!
Drive Fast! Drew
Old 09-09-2022 | 07:32 AM
  #1509
Default Box stock body shell without front splitters
Thanks for sharing the info! I'll go ahead to Dremel off the front splitters of my 12C.
AlvBo is offline
Old 09-09-2022 | 02:02 PM
  #1510
You are better off taping between the splitter and bumper... and staying off of the rails.
AlvBo likes this.
chjosi is offline
Old 09-09-2022 | 04:10 PM
  #1511
Instead of messing with the auto scale RTR body, I just got a Jomurema body and I am SUPER HAPPY I DID!! It doesn't catch the rails unless you really hit them square! It deflects off of them pretty well! It has a pretty generic look, but if you are good at painting I have seen some pretty nice looking paint jobs online! Kenon has them in a few different base colors.
AlvBo likes this.
Old 09-09-2022 | 04:11 PM
  #1512
Scionara05's Avatar
you will be fine I have run the 12c with no fender splitter and a shaved down front bumper. Main thing is shaving the front splitter because it sticks out further then the bumper and put leverage and cracks the front end
Scionara05 is offline
Old 09-09-2022 | 05:24 PM
  #1513
NutDriver's Avatar
I bought one of the new GL Racing Lambo bodies. Before doing anything, I trimmed off the dive planes and the front splitter. I'm hoping that the rounded nose without protrusions will help it fend off walls like the Jomurema, but look better doing it.
chjosi and AlvBo like this.
NutDriver is offline
Old 09-11-2022 | 01:06 AM
  #1514
Hi chjosi, that's an interesting approach and I like that it's a reversible one. I'm trying to visualise how the tape should be installed though.
AlvBo is offline
Old 09-11-2022 | 01:10 AM
  #1515
Hi Drew, that's true. I see quite of few racers using the Jomurema body. It'll be the next project for me.
AlvBo is offline
