MaxAmps 7.4 8000HV Help
Hello,
I have a new in box MaxAmps 8000HV 7.4volt LIPO. I'm new to the lipo thing ( my first one actualy ) Anyway, 2 part guestion: First, could I get a hard case for it throught MaxAmps or do I need to send it to you guys to install. Second, not 100% sure how to charge. Do I need a set number of amps or do I just use my blinky and program the charger for 7.4volt Lipo, at 8000
Hello,
Sorry but we don't offer a hard case for the 8000's.
Set your charger to Li-Po, 2S capacity at 8000 and a max charge rate of 8 amps.
Jason
Jason
I just ordered 2 of these i'm putting only one at a time on a converted slayer im running the Mamba Monster 2200 KV w/ESC do you think i made good descion on battery choice or bad wasnt sure what size to get didnt want nothing to big or small
I'm a little confused, you say your only going to run one at a time on a converted Slayer?? So your going to run a CC Monster 2200 KV motor on one 7.4 volt pack?? If so that's gonna be one slow truck. You should be running them both in series for a 4S set-up. Then you'll have something.
Jason
Jason
Jason
Jason
ok well can i return the battery's to yall in exchange for 11.1 4s when they come in
You may find some useful info here as well: http://www.nitrokillers.com/showthread.php?t=1626
Jason
Well this is what happened yes i'm just starting out in this electric stuff BUT i called Max Amps twice first man talked to said he recommened a 2s pack said it would be plenty for my application then i called back next person talked to said a 4s pack but he said it's just your preference no one said that 2s lipo is junk for CC 2200 until now so i'm screwed wish i could remeber there names i also just called back to see if i get a third different awnser from calling talked to Josh he was great i will be going with the 6500 4s2s so is this going to work and now i read what you said in return's now i have to pay extra %20 for restocking i wish i would have found this thread first instead of calling because im trusting you to many on here say good things about you
As I stated earlier if you have room for the two 8000's you can use them in series with your conversion. If not then yes a 4S 6500 or 5250 would probably better suite your needs. But we can't say for sure because we don't know what type of battery tray your using or how much room you have to start with.
-J
Thanks for talking with me i talked to josh about battery room have planty room to run 8000 im not mad about wrong battery or at yall really happy with you just digusted with having to pay %20 to return them just and man i tried researching them thats why im on this site i called probally 15 different places and no one really said you need atleast this size battery for that motor but i should have looked more i will be back with you for all my battery needs from here on out you the only person i talked to that will explain something and i dont want to run them in series try to keep weight down just only want to run 1 at a time
"Neu-Castle 2200 KV – Intended for up to 6S (25.2 Volt) operation. Incredible in monster trucks with up to 6S lipo packs (4s lipo is the sweet spot), and works great in 1/8 Truggies as well. The 2200 is 75mm long making it capable of handling more power than the 2650. This one is the bad boy!"
The info is out there and we are here to help as best as we can.
Glad to hear you'll have the room for the 8000's.
-J
MAN BIG HELP got the order stopped while it was being processed DIDN'T HAVE TO PAY RESTOCK FEE and i changed to the 6500 4s2p 14.8v now i should be good to go THANKS A LOT i would have been dissapointed when i put those other packs in THANKS
