-   MARCCA Discussion (https://www.rctech.net/forum/marcca-discussion-60/)
-   -   Formula 1 recommendations and rules (https://www.rctech.net/forum/marcca-discussion/766770-formula-1-recommendations-rules.html)
Willie Mann 10-22-2013 09:07 PM
Hello I am interested in running some formula 1 this winter as soon as you guys find a place. I use to race on road at trackside when they had the carpet and am missing the on road action. What is required for the f1 class and what recommendations would you guys make for chassis, tires, upgrades, body, parts, etc?? Also how do you run your f1 races? I have seen uf1 with pit stops and everything or are you just running it like a typical onroad race with 5 min heats?
-Willie Mann
whitrzac 10-23-2013 04:13 AM
21.5
2 cell
'narrow' chassis(f104/etc)
rubber tire
blinky
heats are usually 8min, but we've done up to 12.
Willie Mann 10-23-2013 07:02 AM
Sweet sounds good. Is there a width requirement? Or is narrow like 190mm or less just preffered?
whitrzac 10-23-2013 07:09 AM
Originally Posted by Willie Mann (Post 12658200)
Sweet sounds good. Is there a width requirement? Or is narrow like 190mm or less just preferred?
I forgot the exact measurements, but f104 width is ok, f103 width is discouraged...
liljohn1064 10-23-2013 11:49 AM
UF1 width of 190mm max front and rear with the wheels and tires on the car, front camber adjusted. F104 width rubber tires front and rear. Sliding Kingpin front end with upper arms under the body: no 12th scale front ends, no IFS in the rules at the moment.
Willie Mann 10-23-2013 01:44 PM
Cool I picked up a f104 v2 to race. What tires are most people running?
liljohn1064 10-24-2013 11:27 AM
Last season most ran Shimizu 571 front and either 572 or 575 rears. They lasted all season long and gave great traction.
celt 10-29-2013 05:50 AM
Willy,
Stan from Trackside...but also from Madison.
Keep the front end 190mm and below w/ rubber tires and no one will have an issue.
Willie Mann 10-30-2013 11:01 AM
cool sounds good thanks for the help
FIRE RIDER 11-02-2014 08:18 PM
When I ran f1 it was silvercan mabucci or johnsons with type a rubber. And why exactly are the f103s discouraged? Wth?
liljohn1064 11-05-2014 02:03 PM
It's F1 in the US. Everyone is F104 dimensions now. Is it better, not really. But it is popular and the mfgs are selling kits. Are F103 discouraged. No, just shelved due to popularity. I have 4 F103s and they are pretty much shelf queens. I would check with the national scene if you want more information, especially the UF1 series.
