General MARCCA Questions
Old 01-02-2004, 07:54 PM
  #61
Moderator
Clegg's Avatar
Originally posted by Racin Rev
Elections? We don't need no stupid elections. After we got the dream team in office. What, whith the president and treasurer in the same house, we got what you call centralized government! Don' even think about callin' it conflict of interest, coz we got your conflict right here! Conspiricy!? Racketeering!? don' even start up with them big names, our president fo' life Sadrodm, he got it all figgered out. Jus shut up and hand ovah yo cash!
Hahah now theres a man with my sense of humor
Nepitism Rocks
Clegg is offline
Old 01-02-2004, 08:07 PM
  #62
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
i knew i liked you for a reason rev.....
happy new year
matt
Matt M. is offline
Old 02-01-2004, 07:50 PM
  #63
Neil's Avatar
There was talk about practice for sedans on Monday night. Is this going to happen tomorrow night? If so that would be nice.
Neil is offline
Old 02-01-2004, 08:53 PM
  #64
There is not going to be a sedan practice this Monday night (tomorrow). The scheduling of a practice night needs to be approved by the newly elected board which is going to meet this coming Saturday. I would expect it to be given the green light by the board with next Monday being the starting date. However, it needs to be a board decison.
hybrid is offline
Old 02-01-2004, 09:40 PM
  #65
R/C Tech Founder
More nights being open = more better. Sounds like a good plan to me. We used to do this a few years back and when we got enough people, we'd run a 2-heat/main race, anything goes, just for fun. Sometimes there was even enough interest to do a 4-6 week mini points series.
futureal is offline
Old 02-02-2004, 04:50 AM
  #66
celt's Avatar
As stated by Hybrid, this needs to go before the board and shouldn't be a problem. There are at least four people committed to showing up on Monday nights - this won't be a hollow effort.
I think Monday should work well, the track will be set from the Sunday program, so there shouldn't be a need to remove jumps, design a track and what not - bring in your gear, throw a car down on the track and practice - very efficient for those folks short of time. Having enough to race would be icing on the cake.
Also, If Monday works out, I would appreciate the experienced sedan guys stopping down to help those new to this genre of racing - there is much to setting up these cars.
celt is offline
Old 11-01-2004, 06:40 PM
  #67
Default Track size?
Could someone tell me what the dementions of the track are?
JimmyT is offline
Old 11-01-2004, 07:30 PM
  #68
robob's Avatar
36'x75'
robob is offline
Old 11-01-2004, 07:40 PM
  #69
Thanks for the prompt reply.
I plan to start racing soon and am just trying to select a stock motor based on the size of the track.
JimmyT is offline
Old 11-05-2004, 11:24 AM
  #70
Default Need help getting started
I am new to R/C racing and need a little help getting started in the right direction.
First off I need to select the right pinion gear. I will be running a Monster Pro motor and the instructions suggest using a pinion gear lower (3-4 teeth) than normal stock motors because of it being a high RPM motor. The car manual suggests a 28 tooth pinion. So is it as simple as using a 25 tooth pinion or can someone suggest something better based on their experience?
The stock class requires rubber tires. What rubber tires are best for a carpeted surface?
Thanks for any suggestions anyone may have.
JimmyT is offline
Old 11-05-2004, 11:55 AM
  #71
Moderator
Clegg's Avatar
I am guessing you are talking about a Sedan right? (the rubber tires were a clue) If not then post which kind of racing you are looking at.
Clegg is offline
Old 11-05-2004, 12:37 PM
  #72
Yes, I have a FT TC3 that will be running in a stock sedan class.
JimmyT is offline
Old 11-05-2004, 01:50 PM
  #73
Neil's Avatar
If you are running the stock 72 tooth spur gear a 22 tooth pinion will work fine. That is a overall ratio of 8.57. If you changed the spur grear this would be incorrect. Post up your spur gear if its different and I will figure it out for you.
Neil is offline
Old 11-05-2004, 01:56 PM
  #74
Thanks for the help.
JimmyT is offline
Old 11-27-2004, 04:28 AM
  #75
Rob
Rob's Avatar
Is there a list of classes and rules for the indoor stuff?
Rob is offline
