-   Manila Racers (https://www.rctech.net/forum/manila-racers-33/)
-   -   RC Drifting Section (https://www.rctech.net/forum/manila-racers/54166-rc-drifting-section.html)
rough512 11-04-2004 09:09 PM
Bro,
4 posts one after the other? you could have written all of those in one post.. use the edit button if you have to...
Guys please try to condense your posts into one... avoid double posts...
Blackwrench™ 11-04-2004 11:47 PM
Hey guys,
San kaya naglalaro ng drifting?
di ba masyadong makalat un specially when using PVC tires.
sa bhay lng kasi ako nakakapag drift, using my Mini-z.
mark david 11-05-2004 01:59 AM
Originally posted by rough512
Bro,
D KA NAMAN GALIT NYAN????:lol: :lol: :lol:
slowed2drift 11-05-2004 06:02 AM
:sweat: sorry po... sorry po... :sweat:
FT TC4 racer 11-05-2004 04:55 PM
:lol: :lol: :lol: :ha:
rallyweapon 11-05-2004 08:00 PM
Is there a RC track venue for drifting ? What would be better for drifting: shaft or belt drive 4WD touring cars?
Have tried worn out slicks on 2wd direct drive kits on parquet floors with good effect
vspec101 11-05-2004 10:30 PM
using your rc on a slippery floor is just like using pvc tires :D
4wd is better for rc drifting... 2wd will make ur car spin alot
verve 11-07-2004 04:13 AM
yup! :nod: ...even my bit RC drifts on a slippery floor. :D :lol:
judd 11-07-2004 05:51 AM
slowedtodrift
msta drifting session nyo sa ynares???
zer0_wing 11-07-2004 09:09 AM
judd invite ka nmin sa sat sa ynares...punta ka para dami tau mag drift...wag mo tanungin si slowed2drift ndi nman pumunta yan eh...basta sama ka samin sa sat saya dun sawa ka sa kaka-drift :D :ha: :D :D :D :D
judd 11-07-2004 09:03 PM
di kolam kung makakapunta ako... napunit na ung drift tires ko e...:cry: :cry: :cry: di pa ko nakakabili wala akong tires ngyn
slowed2drift 11-07-2004 09:29 PM
umuulan samin eh... kya di ako nakapunta nung sat sa ynares... :cry: :sweat:
lmagnum 11-08-2004 08:58 AM
you can also try drifting on marble floors/marble tiles using any rubber tires. i tried that sa sala namin nung kinakalikot ko yung yokomo ko. sorex 40 yung tires ko. medyo masikip nga lng. :D
just don't try to trim your steering on it, medyo may kahirapan yun. :D
billysss 11-09-2004 04:32 AM
ULTIMATE DRIFT TIRES
1 Attachment(s)
ETO NA ANG PINOY SOLUTION!!! COURTESY OF YOURS TRULY.
get caps of your WD40 (notice it is 65mm) or the cap of your used engine degreaser (also it is 65mm). Note that your tires are 64mm, (rubbers) CUT THE CAPS in HALF, DREMEL THE MIDDLE WHERE you can fit the tire wrench, NOW FIT IT ON YOUR INSTALLED TIRES. If you have an old tire, its better, or old wheels, better, just CA it or turbo glue it on the tires.
SEE PIC. attached.
silver_spo0n 11-09-2004 04:53 AM
billysss
ygPM
