View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
#8281
Originally Posted by bert control
For Sale : Tamiya Tnx 1/8 Monster Truck
Stock Unit
Almost New
Complete Rtr Kit
--> Tnx Truck, Adspec 2-ch Radio, Glow Plug Igniter, Fuel Filler,
Tamiya Electric Starter And Tamiya Nicd 7.2v Battery For The Starter
I Will Also Include For Free Newly Bought 5-cell Speed Mind 1100 Mah Hump Pack For Receiver ( Once Charged Only)
--> Engine ran for less than 1 gallon gas ONLY!! I Still Have Around 8 Tanks' Worth Of Gasoline Left. It's Yours!!!
Tires And Rims Have Been Changed To Pro Line Maxx Mulcher Tires For Maximum Traction!! I Will Also Give You The Stock Tires Of Tnx Truck!
My Price? Only P 18th!!!
I'm Also Selling My Tlp 4000c Charger, Brand New Condition!!!
P 2,500.00 Only
09209613894
Stock Unit
Almost New
Complete Rtr Kit
P 2,500.00 Only
09209613894
Proline Maxx Mulcher Tires : Reserved
Everything else still available!!! New Price P 17,000.00 ONLY
EVERYTHING SOLD!!!
#8282
Selling for a friend
airtronics m8 digital with receiver.. good condition and still very fresh.
9k
9k
#8283
i'm looking for gs15r engine gud condition, good compression txt me or pm ur offers
09164988513
.09164988513
#8286
For SALE
RC10GT (tub type)
includes:
1 complete RC10GT kit (*from aquimdog)
1 EXTRA complete kit for spare parts
1 OS CZ engine (pull start) *with pipe, clutch assembly and all (with crack on piston head unfortunately)
1 OS CVR engine (non-pullstart) *with pipe, clutch assembly and all
2 Sets of front tires
4 Sets of rear tires
1 Extra set of wheels
2 Bodies
*NEWLY REBUILT
Buy all for only 7k (neg)
Or buy it rtr with a jr xr2 radio and futaba receiver and 2 servos for only 8.5k
Contact me at 09175400177
RC10GT (tub type)
includes:
2 Bodies
*NEWLY REBUILT
#8287
Tamiya TLO1 Ford- 150 SVT Lightning. Good condition with box and manual. All stock. Kit only. With 1400 NP racing pack battery. All for 1.5 K.
Futaba Attack 2ER Stick type Controller. Complete set. with box and manual. With 2 s3003 servo, r122je receiver, with crystals 27mhz. almost new. price 1.6K
No Trades. Serious buyers only!
Text: 09179435318
Text: 09179435318
#8288
Ofna Dominator kit
includes:
hyper 21 engine
lots of extra parts, complete set of arms, pinion gear, etc
new cvd's
new extra dogbones
rear brake kit
some stainless screws
tnx!!
selling for 12k
09195832222
includes:
hyper 21 engine
new cvd's
new extra dogbones
rear brake kit
tnx!!
selling for 12k
09195832222
#8289
Tamiya TL-01 Lancer Evolution IV Monte Carlo
-with oil shocks
-with radial tires
-with stock motor and msc
-with box
-good condition body, painted and decaled like the real car
-no broken parts
-run less than 5 times
1.6K firm
Tamiya M1025 Hummer
-military paint job
-oil shocks
-Manta Ray Hard type propeller shaft
-locked rear bevel diff
-front ball diff
-full ball bearings
-brand new pajero BF Goodrich tires
-stock tires
-with box, manual
-no electronics
-no broken parts
-new 16t pinion
2.5k firm -----------------> SOLD
NOVAK RACER EX ESC
-with box, manual
-no motor limit
-uncut wires
-very slightly used
-will include trinity topaz 11 turn motor --> kakatamad kasi i-unsolder =)
2k firm
la ng tawad yan guys ha =)
0917-5340809
-with oil shocks
-with radial tires
-with box
-no broken parts
1.6K firm
Tamiya M1025 Hummer
-military paint job
-oil shocks
-front ball diff
-full ball bearings
-stock tires
-with box, manual
-no electronics
-no broken parts
-new 16t pinion
NOVAK RACER EX ESC
-with box, manual
-no motor limit
-uncut wires
-very slightly used
2k firm
0917-5340809
#8290
From: 205 2/F Place One Bldg. Katipunan Ave., Q.C. Tel: 949-2129
New Arrival!!!
[Main Specifications]
Maximum electric current: 3120A (FET Spec)
Continuing electric current: 780A (FET Spec)
Unlimited turns
Input Voltage: 4.8~8.4v
Drive frequency: T2.1 Exclusive Atsushi Hara Program (factory set)
Conform Category: All EP
Size: 28.0 x 25.0 x 14.4mm
Weight: 18.8g (Main Body only)
Woven graphite printed case
Silicone code, ultimate shotki diode, ultimate condenser attached
[T2.1’s characteristics]
• Factory programmed
( Atsushi Hara program was installed before shipment )
• Super high-end use specifications
( This product is designed for super high-end focusing on racing and may be unsuitable for beginners. If you are not confident with your skills, please refrain from using it for your own safety)
[T2.1, T2 Common Characteristics]
• Drive frequency, various system settings ( Settings are changeable with Multi setting adaptor VFS 1 card set (by KO Propo – sold separately), or PC and ICS PC interface for VFS-1 (by KO Propo – sold separately))
• Drive frequency
( Settings are changeable by dividing the throttle into 32 sections and each section - 64 steps (0.93~12 KHz))
• Brake frequency
( Changeable FET drive frequencies )
• Neutral Brake
( At throttle neutral position, 0 ~ 50% brake power can be set in 100 different levels )
• Power Save Voltage Function
( set a supply voltage limit in 5 different phases to avoid control inability towards the end of a race. If combined with KO Propo servo & receiver, minimum setting of 2.3V is selectable, allowing you to use power more efficiently
• Current Limiter
( Overall current is adjustable for longer runtimes or if you just have too much power, It can be adjusted by a range of off or 40A~260A range )
• Throttle Response to variable function
( throttle response can be set in 10 different levels, this gives you less punch for slippery tracks and more punch for high grip tracks )
• Heat sink: none
• New switch
( dual function switch allows easy operation )
Check out how the news to see how the Twister 2.1 has been
Unlimited turns
• Drive frequency
• Brake frequency
• Neutral Brake
• Current Limiter
• Heat sink: none
• New switch
#8293
From: Singapore ̡͌ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡V
Looking for good condition Yokomo MR4BC or MR4BC Special with spares.Anyone selling please pm me.Thanks
#8294
1. EAGLE RACING CDC CHARGER ver. 6.0
perfect condition! bought early this year.
7k(neg)
2. NOVAK SMART TRAY(US VERSION)
3.5K(FIXED)
3. TRINITY MONSTER HAULER BAG(3 BOXES)
i've never brought this out of the house!
still in perfect condition, except one box which was dented.
3k(fixed)
for a pic of the bag, here's the link
http://teamtrinity.com/bags/bags.html
4. KO PROPO HIGH TOURQUE/ SPEED DIGITAL SERVO(2343)
3.5k(fixed)
*All items come with their respective box and manuals. Pictures available upon request.
serious buyers please!!!
pm or text me at 09178234902
7k(neg)
3.5K(FIXED)
3k(fixed)
3.5k(fixed)
#8295
Team Associated B4 (2WD off-road buggy) - Team Car
-> with novak GT7 speed control (can handle motors with lower turns)
-> futaba 9101 full ball bearings servo (steering servo)
-> stock motor
-> 3000 nimh battery (for bashing)
-> JR XR3 FM radio complete with RX/XTAL with 8 rechargeable batteries
-> 2 pairs extra set of tires (rear proline racing tires with rims)
P11,000 (or best offer can be traded to airsoft guns(gas/aeg))
917-8232518/916-4801457
-> stock motor
1Likes
