Electric Touring / On-Road RC
Hi thanks for asking,
About lipo battery for your HPI sport2.
You can use round shoulder type lipo battery If it can be fit a square type hard case lipo battery.
Lil's hobby has fully max brand and action hobby has also some of round shoulder type lipo I think.
May call those hobby shop then Please ask them.
About your ESC, what is your ESC model please?
By the way which class you are planning to run?
taka
taka
Hi thanks for your help,
My esc is the flux vapor, it's an hpi badged castle sidewinder sv2
My motor is the flux vektor, sensorless 5900kv
If those will be allowed in the 4wd open class then I'll probably run
Thanks again !
Your ESC has no problem to use in this class. But Motor is too much power if compare to ordinary 17.5T brushless motors.
Usual KV for 17.5T motor is 2200 to 2800KV actually.
Can you please prepare some other motor 17.5T or tamiya 18T please?
I guess your ESC can use even the motor is a sensored type.
"tamiya 18T and open 17.5T 4WD open class is kind of a competitive class in this race event. I must be strict for this class car regulation. Im sorry to tell you this.
So, you options are any 17.5T brushless motor or tamiya 18T brushless motor to join this class. If you really can't find it, final option is I rend you mine tamiya 18T.
I am very welcome to new racers so why not i help you if you want to join our race event.
May mgpraktis ba sa JP this Saturday?
Hello my friends, Id like to present you Trophy on road racing event again.
I have a new exited class again with this 2015 first mighty gripper cup. Please check.
PLACE: Of course the great indoor race track "JP RACEWAY".
DATE and TIME: June. 27 (sat) 1pm start first heat of qualifying.
Classes: "Jr. limiter cut class!"
"FF tamiya 18T and open blinky 17.5T class"
"Stock tamiya TT class"
"M-chassi tamiya 18T and open blinky 17.5T class"
"4WD tamiya 18T and open blinky 17.5T class"
Trophy: For all A-main class top 3 racers.
Qualifying: 15 minutes track open, best fastest lap style two times for each class.
finals: each class 3 times. (Drop one heat point. If tie-break, best run time.)
For each class Car rules are below.
Age limit: until 15 years young only.
Chassis: Any 1/10 scale any brand on road electric RC car.
Motor: Any above 17.5T brashness or any above 23T brash motors can be use.
FDR: Its open.
Tire: Open for rubber and foam. (Not allowed fabricated tires)
Body-shell: Open for 1/10 scale RC bodies.
ESC: Open for no timing or blinky mode ESC.
Battery: Open for 7.4V 2S lipo battery.(hard case is required)
Chassis: Open for 1/10 scale electric Front drive chassis.
Motor: Tamiya 18T or open brand 17.5T brushless motor.
FDR: Open.
Tire: Tamiya tires only can be use.
Body-shell: Open for 1/10 scale tamiya FF body.
ESC: tamiya 18T motor required tamiya ESC. 17.5T no timing or blinky mode ESC.
2015 lils Tamiya TAC rules.
Chassis: tamiya M-03, M-05, or M-06 can be use.
Motor:Tamiya 18T or open brand 17.5T brushless motor.
FDR: No speed tune gear (only tamiya). pinion only 19T can be use.
Tire: Any brand. Open for 60D size tires.
Body-shell: Open for tamiya M-chassis body.
Chassis: Any brand. Open for 1/10 scale electric touring car.
Motor: Motor:Tamiya 18T or open brand 17.5T brushless motor.
FDR: Open.
Tire: Only tamiya brand tires, wheels, and insert.
Body-shell: Only tamiya 1/10 scale bodies can be use.
Battery: Open for 7.4V 2s lipo battery. (hard case is required)
For your info, This race might have racers from other islands of Philippines a lot!!
I think this event must be hottest and biggest manila on-road RC race till now in this year.
Please get your gear ready on June. 27 my friends!
(Organizer me taka and Arnold daluson)
Entree fee: First entree 550PHP
Additional class entree fee each 150PHP
FDR: Its open.
FDR: Open.
FDR: Open.
Thanks for the purple tape and looking forward for this event, as well as extending best regards to Arnold Dalusong
My friend,
If I do borrow your tamiya 18t, I'll go there early so I can mount it, and then give it back to you as soon as my leg is done. Thanks.
Will you be strict about tamiya bodies and tires, because if i can, I'd rather not spend, and run my HPI stuff ?
p.s is there any event where I can run my dad's 12t kyosho, 16t trinity and kyosho 16t because those motors are older than me, and itching to race.
unfortunately most of the races have shifted to brushless systems due to their convenience...
Up dates for June 27. Mighty gripper cup
Hello my friends and RC car racing lovers!
Here is edited rules kindly please check it out.
Also trophy is going to pass for all winners on the race day.
There is attention please,
"Qualifying is best fastest Lap.(2 times of 10-15 minutes track open for each class)"
"Race heat at least 3 heats maximum 5 heats.(if 3 heats drop 1, case 4 heats drop 2, then incase 5 heats drop 3 heats point.)
"Our target finishing event time is 9pm."
"Qualifying will start from 11 am sharply."
"All class tire insert(only insert) will be open brand due to we can't check it without destroy tires."
"4WD tamiya 18T and open 17.5T blinky class body will be open brand. But still tamiya rear wing is required to all brand bodies."
"M-chassis body can't put wing if the wing is not comes with body."
The newest rules are here below.
"Junior & Senior limiter cut class" (added Senior here)
Age limit: until 15 years young or 55 years old above (55 years old can).
Chassis: Any 1/10 scale any brand on road electric RC car. (F1, touring, M-chassis, off road cars, as long as 1/10 size)
FDR: Open.
Body-shell: Open for 1/10 scale RC bodies. Rear wing open for all brand.
Weight: No limit.
Brushless moter timing: Case 17.5T Motor, Timing motor side is MAX thirty degrees. (0-30 degrees)
FDR: Open.
Tire: Tamiya rubber tires only can be use.
Body-shell: Open for 1/10 scale tamiya FF bodies and tamiya Hatch back type bodies.
Weight: No limit.
Just 2015 lils Tamiya TAC rules.
(Will check FDR after each heat for top 3 finisher of qualifying and race.)
FDR: No speed tune gear (only tamiya). Max size of pinion gear 20T.
(You can't change your chassis after start race event and gear inspection after qualifying and race. You can use only one chassis for this event. spare car not allowed.)
Tire: Any brand. Open for 60D size rubber tires.
Weight: No limit.
FDR: Open.
Tire: Only tamiya brand rubber tires, wheels can use. The Insert is open brand.
Body-shell:tamiya 1/10 scale bodies and open brand 190mm touring car bodies can be use. (protoform, HPI, and any other 190mm 1/10 bodies can be use)
Wing: Only tamiya rear wing allowed to use. (even other brand bodies tamiya rear wing is required.)
Car weight: Minimum 1420g with ponder before run.
I think this event must be hottest and biggest manila on-road RC race till now in this year. From cebu 6 racers, From surigao 1 racer already confirm
Please get your gear ready on June. 27 !
FDR: Open.
Weight: No limit.
FDR: Open.
Weight: No limit.
Weight: No limit.
FDR: Open.
2015 first Mighty Gripper Cup participants.
Hello my friends and players, Please fill-up your name if you are going to join the race before June.10.
If the class has no entry at least 5 persons within June.10, the class will be cancel from this event.
Junior and Senior limiter cut class.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
1. Didi
2. Jomark
3.
4.
5.
6.
7.
8.
9.
10.
1. Chito
2. DiDi
3.
4.
5.
6.
7.
8.
9.
10.
M-chassis tamiya 18T and open blinky 17.5T class
1. Didi
2.
3.
4.
5.
6.
7.
8.
9.
10.
1. Mikey
2. Gerry
3. Jomark
4. Didi
5. Jun manego
6. atty Joyie
7. Dan
8. Benjie
9. Chito
10.
11.
12.
13.
14.
15.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
1. Didi
2. Jomark
3.
4.
5.
6.
7.
8.
9.
10.
1. Chito
2. DiDi
3.
4.
5.
6.
7.
8.
9.
10.
1. Didi
2.
3.
4.
5.
6.
7.
8.
9.
10.
1. Mikey
2. Gerry
3. Jomark
4. Didi
5. Jun manego
6. atty Joyie
7. Dan
8. Benjie
9. Chito
10.
11.
12.
13.
14.
15.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
1. Didi
2. Jomark
3.
4.
5.
6.
7.
8.
9.
10.
1. Chito
2. DiDi
3.
4.
5.
6.
7.
8.
9.
10.
1. Didi
2. Miles
3.
4.
5.
6.
7.
8.
9.
10.
1. Mikey
2. Gerry
3. Jomark
4. Didi
5. Jun manego
6. atty Joyie
7. Dan
8. Benjie
9. Chito
10.Miles
11.
12.
13.
14.
15.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
1. Didi
2. Jomark
3.
4.
5.
6.
7.
8.
9.
10.
1. Chito
2. DiDi
3.
4.
5.
6.
7.
8.
9.
10.
1. Didi
2. Miles
3.
4.
5.
6.
7.
8.
9.
10.
1. Mikey
2. Gerry
3. Jomark
4. Didi
5. Jun manego
6. atty Joyie
7. Dan
8. Benjie
9. Chito
10.Miles
11.
12.
13.
14.
15.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
1. Didi
2. Jomark
3.
4.
5.
6.
7.
8.
9.
10.
1. Chito
2. DiDi
3.
4.
5.
6.
7.
8.
9.
10.
1. Didi
2.
3.
4.
5.
6.
7.
8.
9.
10.
1. Mikey
2. Gerry
3. Jomark
4. Didi
5. Jun manego
6. atty Joyie
7. Dan
8. Benjie
9. Chito
10.
11.
12.
13.
14.
15.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
1. Didi
2. Jomark
3.
4.
5.
6.
7.
8.
9.
10.
1. Chito
2. DiDi
3.
4.
5.
6.
7.
8.
9.
10.
1. Didi
2.
3.
4.
5.
6.
7.
8.
9.
10.
1. Mikey
2. Gerry
3. Jomark
4. Didi
5. Jun manego
6. atty Joyie
7. Dan
8. Benjie
9. Chito
10.
11.
12.
13.
14.
15.
just a clarification, can I use HPI magwheels, cause my set-up is staggered, 24mm tamiya tires, on tamiya mags in front, and 26mm tamiya tires, on HPI magwheels in the back. Will my tires set-up be allowed , or is it strictly Tamiya for everything except the insert.
See you there (hopefully)
2015 first Mighty Gripper Cup participants. (as of Jun.8)
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
1. Didi
2. Jomark
3. Rains
4.
5.
6.
7.
8.
9.
10.
1. Chito
2. DiDi
3.
4.
5.
6.
7.
8.
9.
10.
1. Didi
2.
3.
4.
5.
6.
7.
8.
9.
10.
1. Mikey
2. Gerry
3. Jomark
4. Didi
5. Jun manego
6. atty Joyie
7. Dan
8. Benjie
9. Chito
10. Rains
11.
12.
13.
14.
15.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
1. Didi
2. Jomark
3. Rains
4.
5.
6.
7.
8.
9.
10.
1. Chito
2. DiDi
3.
4.
5.
6.
7.
8.
9.
10.
1. Didi
2.
3.
4.
5.
6.
7.
8.
9.
10.
1. Mikey
2. Gerry
3. Jomark
4. Didi
5. Jun manego
6. atty Joyie
7. Dan
8. Benjie
9. Chito
10. Rains
11.
12.
13.
14.
15.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
1. Didi
2. Jomark
3. Rains
4.
5.
6.
7.
8.
9.
10.
1. Chito
2. DiDi
3.
4.
5.
6.
7.
8.
9.
10.
1. Didi
2.
3.
4.
5.
6.
7.
8.
9.
10.
1. Mikey
2. Gerry
3. Jomark
4. Didi
5. Jun manego
6. atty Joyie
7. Dan
8. Benjie
9. Chito
10. Rains
11.
12.
13.
14.
15.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
1. Didi
2. Jomark
3. Rains
4.
5.
6.
7.
8.
9.
10.
1. Chito
2. DiDi
3.
4.
5.
6.
7.
8.
9.
10.
1. Didi
2.
3.
4.
5.
6.
7.
8.
9.
10.
1. Mikey
2. Gerry
3. Jomark
4. Didi
5. Jun manego
6. atty Joyie
7. Dan
8. Benjie
9. Chito
10. Rains
11.
12.
13.
14.
15.
