Electric Touring / On-Road RC
#241
Baluga: we'll be in PS1 tom (sun) pero konti lang yata kami. happy naman ako sa type S but i wanted to try the type RR. externally, brush layout ang naiba, but im not sure kung iba rin ang armature nito. pareho silang 23x1 but baka merong ibang kalikot na ginawa ang tamiya to differentiate the 2 motors.
Tmak: text me kung makakapunta kang makati, dadalhin ko yung lightweight type S siguradong wala na tong binding kasi bawas na yung magnets ok yung link sa tamiya motors, ngayon ko lang nalaman na 23x1 din pala yung dyna run stock, kala ko 13x2 yun na bushing version ng dyna run black can.
#242
Originally posted by Baluga
Sorry pare di ako nakasagot sa sms mo, naubusan ako ng load eh. Ang mahal naman ng body mounts. Apat na piraso ba iyon? Baka pwede ka sunday sa PS1, doon tayo maghabulan. Magkano mo binenta yung RR?
#243
Originally posted by Nardong Putik
sulit naman yung body mounts na nabili ko bro. i think it has 5 pairs of body posts, transponder holder and antenna mount. txt kita saturday night kung pwede ako sunday morning. dami kasing obligasyon dito sa bahay eh. 500 ko lang sinalba yung type rr ko. barkada ko rin kumuha eh...
#244
#245
mga 11am siguro hanggang hapon na
#246
#247
Dami ko na miss!!! kakainis naman.
#248
Re: Re: Non-Pro Beginner
Originally posted by TambokGT
290 is not good... a good temp is 240 to 255.....dont' go over 260.
What % nitro are you using?
What brand of fuel you are using for your engines and how much nitro percentage?
#249
any up-coming race shecdule!!
#250
New RC Fanatic Needs Help™
Hi Manila Racers,
Stealth recommended these forums to me and was wondering if anyone had good links to Philippine based RC websites. I am just getting into the hobby and thought that this would be a good place to start.
I'm looking to get into anything RC related and need to know all the to best place to look online. Then, make a decision on what I should get. I really like the Savage 25 but maybe through discussions at these forums, someone will make me change my mind.
I here that Action Hobbies and Pitstopcafe are good sites but I can't seem to find them on the web using a search engine. Can I get a little help here?
Thank you all in advance for helping out. Looking forward to hearing from you all very soon.
Cheers,
Toolbox™
Cheers,
Toolbox™
#251
online websites
try..
manilahobbies:
http://www.manilahobbies.com
pitshop cafe:
http://www.pitshoponline.com
or go to this thread ---> Important: Hobby Shop and Track Info./Directory
http://rctech.net/forum/showthread.php?s=&threadid=8835
and you can read this... http://rctech.net/forum/showthread.p...threadid=31587
manilahobbies:
pitshop cafe:
#252
2004 Tamiya Philippine Cup Rules Ver. 1.1
TAMIYA Philippine-CUP 2004
RACE REGULATIONS
General
1.Cars must be built with original Tamiya parts, strictly following the instructions provided with those parts.
2.All parts must be used as supplied in the package and/or cut as outlined. Changes, which modify the original appearance of the car, are not allowed. In the classes of GT-1, Stock Touring, TL-01 Spec, and M-Chassis, tires/wheels must stay within the width of the body of the car.
3.Crystal of radios must be changeable. A third crystal should be prepared.
4.Motors must be Tamiya brand. Refer to each category regulations regarding information about motors etc.
5.No tire performance enhancing materials are allowed.
6.Each qualifying race will be of 5 minutes duration plus the time to complete the last lap.
7.Only modifications outlined in the regulations are allowed.
8.Any other issues not clarified in the regulations shall be handled at the discretion of the race organizer.
Special Note: Regarding 49*** series parts, only the color version of SP/OP parts which are listed in the parts list are allowed.
CAR REGULATIONS of 4WD GT
1.Only the following chassis are permitted to be used in this class:
TA03F, TA03F Pro, TA03RS, TA03R, TA03FS, TA-04 PRO, TA04, TA04S, TA04SS, TA04R, TA04RR, TA04-TRF, TL01, TT-01, TB01, TB-02
2.Only Tamiya Made batteries can be used. Battery wires can be modified at the bottom of connector to accept other types of speed controller connectors. Wire length must exceed 3cm.
3.Only the following motors are permitted to be used in this class:
540 Motor
Sport-Tuned Motor,
Super Stock Type-R Motor,
Super Stock Type-S Motor (#49247)
Super Stock Type-T Motor,
Super Stock Type-RR (#49260)
Super Stock Type-RR/Gun Metal (#49288)
Dyna-Run Racing Stock
Dyna Run Super Touring
Super Modified Motor 11T
4.Motor brushes must be from Tamiya. Modifications such as slotting, serrating, etc. are prohibited.
5.Cars do not have to be equipped with cockpit detail or a driver figure.
6.Any attempt to modify or to influence the ability of the motor is not allowed. However, wires of speed controller can be soldered to motor.
7.Minimum permissible weight of car when ready to run is 1,500g.
8.Any parts from TRF414X, TRF414, TRF414M, TRF414M2, & TB-Evolution series are not permitted except those which are commonly used for TA-04 type kits and TB-02 chassis.
9.Clearance under main chassis parts must exceed 5mm before the race.
CAR REGULATIONS of FORMULA-1
1.Only the F201 Chassis is allowed in this class.
2.Only Tamiya Made batteries of up to 2400 mAh capacity can be used. Battery wires can be modified at the bottom of connector to accept other types of speed controller connectors. Wire length must exceed 3cm.
3.Only the following motors with up to 23T are permitted to be used in this class:
Sport-Tuned Motor
Super Stock Type-RR Motor (#49260)
Super Stock Type-RR/G. Metal (#49288)
5.Any attempt to modify or to influence the ability of the motor is not allowed. However, wires of speed controller can be soldered to motor.
6.Cars must be equipped with a driver figure.
7.Minimum permissible weight of car when ready to run is 1,400g.
8.Clearance under main chassis parts must exceed 3 mm before the race.
CAR REGULATIONS of Stock Touring Class
1.Only the TL-01 and TT-01 chassis are permitted to be used in this class.
2.Only a 3 step mechanical speed controller is permitted to be used in this class.
3.Drivers are limited to Tamiya-Made batteries of up to 2400mAh capacity only. No modifications to the battery wires or connectors are allowed.
4.Standard Johnson 2-vent RS-540 Motors must be used. Drivers must use the motors as provided including wires. Any attempt to modify or to influence the ability of the motor is not allowed.
5.Cars do not have to be equipped with cockpit detail and/or a driver figure.
6.Minimum permissible weight of car when ready to run is 1500 g.
7.Clearance under main chassis parts must exceed 5mm before the race.
8.The ff. Bodyshells CANNOT be used:
Honda NSX JGTC
Nissan Skyline JGTC
Nissan R390
Toyota Supra
Mercedes Benz CLK-GTR
Ferrari 360 Modena
Chevrolet Corvette
HKS Altezza
9.Racers must use only DTM series bodies, other touring car bodies, or rally car bodies. The use of the Lightweight Rear Wing Set is prohibited.
10.Tamiya Hop-ups for the TL-01, TL-01LA, and TT-01 are allowed
Special Note: We will issue ASAP the gearing limits for stock touring class. TL-01 chassis will still be limited up to 19T pinion with TL-01 Speed tuned gear set. TT-01 gearing shall be updated at a later date.
CAR REGULATIONS of M-Chassis Class
1.Any Tamiya M-chassis car (M01, M02, M02-L, M03, M0-3L, M04L, M-04m) is allowed in the Philippine eliminations. But the M0-3, M-03L, M0-4L and M04m will be the only chassis allowed for the 2004 Tamiya Asia Cup.
2.Tamiya Hop-Ups allowed, no chassis lightening allowed.
3.A proper m-chassis body must be used with its proper chassis. I.E. (FWD front wheel drive body must be used with front-drive chassis. RWD rear wheel drive body must be used with rear wheel chassis)
4.Cars may run any Tamiya tires designed to fit the "M" chassis. The tires and wheels must conform to the scale look of the body. Running 26mm sedan wheels and tires on a Mini Cooper body would be an example of what wouldn't be allowed. The Porsche Boxster, Porsche 911, Mercedes SLK, BMW M Roadster and Honda S2000 may only use wheels and tires that are of the 26mm type. 24mm wheels and tires are not legal for the 2004 season. Using the smaller wheels on a M-04 or long wheeled base M-02L is not legal unless the body type warrants it.
5.Porsche Boxster, Porsche 911, Mercedes SLK, BMW M Roadster and Honda S2000 may not run extra wide or offset wheels.
6.Motor Regulations identical to Formula-1 class.
7.Due to the recent amount of disparity among the different mini chassis types, the following gearing rule will be in effect for the 2004 season. Because the M-04 uses the bigger sedan tires and offers an overall gearing advantage compared to the older smaller tired minis, the M-04 will be restricted to the 17-tooth pinion as of the 2004 season.
The following is the maximum size gears that are allowed for each mini chassis type:
M0-4 with Sedan type tire: max pinion 17 tooth
M-04m (Alfa body only) with 60D tires: max pinion 19 tooth
M0-3 with 60D tires: max pinion 20 tooth
M0-1/2 with 60D tires: max pinion 20 tooth
M0-1/2 with 26MM sedan tires: max pinion 18 tooth
Running a M0-3 with sedan tires is not legal for 2004.
note: The TL-01 Spec class is intended for Novice drivers. Participants wishing to enter a spec type class that is of intermediate to expert ability should opt to enter the Stock Touring Class. It will be at the discretion of the Organizers to weed out drivers who are attempting to enter this class, that are of better ability, to bump them up to a different category.
CAR REGULATIONS of TL-01 Spec Class
1.TL01, TL-01 LA chassis kits only.
2.The Only Hop-Ups allowed are:
a. Tamiya plastic oil-filled shocks (50519, requires 2 sets)
b. Ball bearings
c. TL-01 Turnbuckle steering tie rod set (53300)
d. TL-01 long suspension arm set (53467) The sway bar set in this kit may not be used for Spec, but may be used for Stock Touring.
3.Motor and rules similar to Stock Touring class.
4.Battery rules similar to Stock Touring class.
5.Gear Ratio limits are identical to Stock touring class
6.You must run kit type tires (Racing Slicks {50454}, Racing Radials {50419}, Racing Semi Slick Tires {50810}
7.Any tire insert may be used.
Updated, February 21, 2004
Posted, February 22, 2004
Note: Updates and revisions shall still be forthcoming. But this is more or less the rules that we shall use for the 2004 season
RACE REGULATIONS
General
540 Motor
Sport-Tuned Motor,
Sport-Tuned Motor
Honda NSX JGTC
Nissan Skyline JGTC
Nissan R390
Toyota Supra
Ferrari 360 Modena
Chevrolet Corvette
HKS Altezza
b. Ball bearings
#253
Tamiya Cup Series
Race na!!
Pasok pa ba TT-01 ko dyan?
#255
Grrrr!!!
Sa battery pa lang disqualified na ako.
