Mini/Micro RC
#6931
#6932
went to boom na boom... and saw this...
looks like mini-z track is made by atomic.... haven't been able to run on it... kasi it was raining... pero looks interesting...
#6933
boom na boom mini z track
sir rad pwede ba tayong maglaro dyan on saturday. what would be the size of the track it self. pm mo lang ako sa friday kung tuloy , pwede ako saturday afternoon. see you
#6934
hi carlo_m... slightly covered siya kaya tinakpan nila dahil nababasa pag umulan ng malakas... i think mas maliit ito compared to the speedway... di ako pwede pag saturdays... sunday naman is familyday...
#6936
nasa pit area nga ang track... i don't think it would be too much of a bother... kung wala sila dun... will just have to schedule kung wala sila dun...
kung dun din sila... ok lang naman din... da more da many er...
#6937
Just call lei at 4745208 to ask for schedule
P100 only wholeday if you will charge battery, if not wla bayad
#6938
Firelap mini z available at boom na boom at very low price
#6940
gear
mga boss papano po kalasin to pa help naman po
#6941
nakapatong lang ang planetary gears dyan.... base on the picture all those gears would come out na naturally by pulling it with your fingers.
Ang tanging lock nyan ay ang C clip which have been removed na kaya ang cover ay nakakalas na ...
ganito ang itsura ng C-clip
http://www.tedani.com/images/c-clip-2-5.jpg
#6945
here's what it looks like when taken apart... the iwaver/firelap gear diff may be different, but basically its the same... the gears just slide off the axle... you'll have to take the whole diff out of the motor pod first... the e clip goes into that slot on the left side of the axle... hope this helps
