Serpent 710 chat
#46
Originally Posted by MAVICXXX
yzza..crash got downtime less now,15secnds..
but realy can c d chasis dfnrt handlg...
#47
Originally Posted by BundyMan
Maybe a kawahara upper deck would be nice
#48
Originally Posted by crashed_1
No need lah..print money meh...
#49
Ok, enough OT... Below is what I ran last weekend at TT on the large layout.
It was some time I had not had a run at TT. Last weekend was the first time I ran since they laid the new tarmac ! I am currently still running with a front ball diff and the new low CG chassis.
Suspension geometry Front:
Downstops: 1mm
Set-up ride height: 6mm (Actual ride height !)
Camber Left: -2.0 degree
Camber Right: -2.0 degree
Track-width: 200mm
Toe-in: -1.0 degree (Toe-out)
Caster setting (mm in front): 5mm (with wheelbase shortened 2 mm)
Roll-center position upper arm (mm): 0mm under
Upstop (mm): None
Suspension geometry Rear:
Downstops: 9mm
Set-up ride height: 7mm (Actual ride height !)
Camber Left: -4.5 degree
Camber Right: -3.5 degree
Toe-in: +2.5 degree
Track-width: 200mm
Roll-center position upper: inner (UTI)
Roll-center position lower: up (LT)
DRS arm position (low-mid-up): mid (neutral)
Shockabsorbers Front:
Springs: Red
Oil: 40W
Holes: 4 x 1.2 mm
Cilinder type: composite
Membrane: Red
Shock-tower position: 2nd hole
Shockabsorbers Rear:
Springs: Red
Oil: 40W
Holes: 4 x 1.2 mm
Membrane: Red
Shock-tower position: 1st hole
Lower shock position: outside
Anti-roll bar front:
Thickness: None
Position: None
Anti-roll bar rear:
Thickness: 2.5 mm
Position: 11.5 mm from the end of bar
Position on lower arm: Inside
Tires Front:
Make: Jaco Tires
Hardness Left: 42 shore
Hardness Right: 42 shore
Diameter: 62.5mm
Wear in 5 min. Left:
Wear in 5 min. Right:
Tires Rear:
Make: Jaco Tires
Diameter: 64.5mm
Transmission:
Pinion 1st: 16T
Pinion 2nd: 22T
Gear 1st: 61T
Gear 2nd: 57T
Front axle:
Type: Adjustable ball diff
Diff. setting: Medium hard (when hot)
Rear axle:
Diff. setting: medium soft (when hot)
Aerodynamics:
Body: Protoform Mazda 6
Wing: Standard level to the body roof
Gurney strip: -
Engine and pipe:
Engine: NovaMax
Version: P12
Head shims: 0.2mm
Glowplug: 7TF
Pipe: NovaMax 2602T inline pipe
Header: -
Length: -
Fuel: 25% Model Technic
What can I say... The chassis is DA BOMB ! The rear end stays planted and loads of steering even with hard tires.
Downstops: 1mm
Track-width: 200mm
Upstop (mm): None
Downstops: 9mm
Toe-in: +2.5 degree
Track-width: 200mm
Springs: Red
Oil: 40W
Holes: 4 x 1.2 mm
Membrane: Red
Springs: Red
Oil: 40W
Holes: 4 x 1.2 mm
Membrane: Red
Thickness: None
Position: None
Anti-roll bar rear:
Thickness: 2.5 mm
Tires Front:
Make: Jaco Tires
Diameter: 62.5mm
Tires Rear:
Make: Jaco Tires
Diameter: 64.5mm
Transmission:
Pinion 1st: 16T
Pinion 2nd: 22T
Gear 1st: 61T
Gear 2nd: 57T
Front axle:
Rear axle:
Aerodynamics:
Gurney strip: -
Engine and pipe:
Engine: NovaMax
Version: P12
Head shims: 0.2mm
Glowplug: 7TF
Header: -
Length: -
#50
Originally Posted by thamjk
hei guys anybody is using this new option part. How is the feedback?
The new CHASSIS is a must have whatever the reason!
Oh, save some money for the new shocks too ... really VERY good.
#51
Originally Posted by InitialD
You mean copy lah again?
#52
But you Paris Hilton macho mah.
LMAO
#53
#54
Downstops: 1mm
Track-width: 200mm
Upstop (mm): None
Downstops: 1mm
Track-width: 200mm
Upstop (mm): None
#55
Can't blame Prof D la, he's been away from RC for so long and hence the continuation of using a front diff
#56
#57
Nowadays most Serpent Factory drivers are runing the front diffs...
#58
Guest
#59
Originally Posted by tornado
We must follow kah ?? *****cabut*****
#60
Guest
We must try to see if there are advantages or not...
