VXR Racing
#151
New Product Release - Piston Power Series & Nitro Accessories
VXR Racing released its Piston Power series and Nitro Accessories Series. They include high performance pipes for 1/10 on road, 1/8 off road, Savage and Revo pipes. Many accessories are also part of the release.
For more information, please refer to:
VXR Piston series
VXR Nitro Accessories
Part numbers include:
NPT-1205 X1 1/10 In-Line Tuned Pipe Set - 5mm
NPT-1206 X1 1/10 In-Line Tuned Pipe Set - 6mm
NPM-R250 Burst Tuned Pipe Set for REVO
NPB-R210 Fire R 1/8 Buggy In-Line Tuned Pipe Set (RPM)
NPB-T210 Fire T 1/8 Buggy In-Line Tuned Pipe Set (Torque)
NPM-S250 Rage Tuned Pipe Set for SAVAGE
NEG-1202 .12 Silicone Gasket - 2pcs
NEG-1502 .15 Silicone Gasket - 2pcs
NEG-2102 .21 Silicone Gasket - 2pcs
NEG-P1202 .12 Silicone Gasket (Picco) - 2pcs
NES-1202 .12 Manifold Spring - 2pcs
NES-2102 .21 Manifold Spring - 2pcs
NES-0003 Manifold-Pipe Spring - 3pcs
NEA-1000 Exhaust Stay
NFR-1202 On-Road Air Filter - 2pcs
NFB-2104 1/8 Buggy Air Filter Foam Element (4)
NFB-2105 1/8 Buggy Air Filter Set
NFT-0100T Silicone Fuel Tubing - 100cm (ID:2.4mm OD:5.5mm) Transparent
NFT-0100FG Silicone Fuel Tubing - 100cm (ID:2.4mm OD:5.5mm) Flr Green
NFT-0100FY Silicone Fuel Tubing - 100cm (ID:2.4mm OD:5.5mm) Flr Yellow
NFT-0100FP Silicone Fuel Tubing - 100cm (ID:2.4mm OD:5.5mm) Flr Pink
NFT-0100FR Silicone Fuel Tubing - 100cm (ID:2.4mm OD:5.5mm) Flr Red
NFT-0100FO Silicone Fuel Tubing - 100cm (ID:2.4mm OD:5.5mm) Flr Orange
NFT-0100FB Silicone Fuel Tubing - 100cm (ID:2.4mm OD:5.5mm) Flr Blue
For more information, please visit VXR Web Site at www.VXRracing.com
#154
New Product Release - 5 Amp Regulator (6.7V) for Li-Po RX Packs
LVR-5000
5A Switching Regulator (6.7V) for Li-Po Rx Packs
Regulator Technology: Switching
Assembly Technology: Surface mount
Weight (including wire and connector) : 9 grams
Dimension (excluding wire and connector): 20 x 40 x 7 mm
Output voltage: 6.7 Volts
Max continuous current: 5 Amp
Input Connector: JST - RCY Polarized
Output Connector: 'J' Type
Wire length: 12 cm
Recommended Application: 1/10th GP and 1/8th GP On-road and Off-road
A breakthrough in R/C car racing with Li-Po Technology! The 5 Amp regulator was designed specifically targeting the 1/10 & 1/8 class for both on-road and off-road. Advancement in servo technology has brought more powerful and reliable servos into the race arena but with one drawback – ‘power consumption’. These servos draw more current than their predecessors and therefore need higher capacity batteries. That is why manufacturers are pushing for higher capacity receiver batteries for racing.
The VXR advantage:
This is where VXR Racing steps in pushing the envelope further in battery technology to achieve maximum racing performance. Below is the advantage of running this regulator with any one of our VXR Racing Li-Po pack:
1) You will have consistency in steering torque and speed throughout the race. Braking and throttle servo performance will stay consistent all the way. Why this happens is because the regulator maintains a constant voltage (6.7) at any level of current draw, up to 5amp. With NiMh, as soon as there is current draw (servo movement) the supplied voltage dips and that causes a change in speed and the holding power of your servos, affecting your response to steering input. Consistency wins races!
2) Improved runtime
3) Reduced overall weight of your race car.
Features:
1) Li-Po low voltage detection - red LED will light up when detecting Li-Po battery voltage is 6.2v or lower. This is to prompt the user to recharge the Li-Po battery. The system will continue to function until the voltage drops below your electronics’ minimum operating voltage.
2) Functional LED - a green LED will light up when it is powered up to show the unit is functioning.
3) Clear heat shrink protection - It allows the LED to be viewed clearly.
4) Single sided SMT - while SMT technology ensures high quality and consistency, the single sided assembly allows the bottom of the regulator to be flat for easy mounting with double sided tape.
5) No switch equals less problems. Switches are frequently a reliability issue. In racing, reliability is more important than convenience, therefore the lack of a switch in this product.
For more information, please refer to www.VXRracing.com
#155
5Amp Switching Regulator and Li-Po Rx Packs Promotion
VXR Product Launching Promotion (Malaysia only)
Purchase the following:
Get this FREE!
VXR Racing’s breakthrough in the use of Li-Po for powering R/C electronics allows the driver to achieve maximum racing performance. This ultimate upgrade will move you into the new generation of Li-Po technology. This combination will replace ordinary Ni-MH batteries that power your receiver and servos. Not only will it reduce the weight of your car, it will ease your mind when it comes to receiver pack runtime as well as improved consistency in your servos. The VXR 5 Amp regulator is designed and built for all gas powered racing. Coincident with the launch of the 5 Amp Switching Regulator, VXR Racing is glad to present all hobbyists in Malaysia with the following promotion.
Purchase the following for RM199
1) 5Amp Switching Regulator (6.7V) for Li-Po Rx Packs (LVR-5000)
2) Receiver Pack – Li-Po, 750mAh, 2S1P, 7.4V (LRX-0750)
And VXR Racing will throw in one Receiver Pack – Li-Po, 500mAh, 2S1P, 7.4V (LRX-0500) absolutely FREE!
Normal MSRP for all 3 items: RM349.50
Availability: 20 sets only (first come, first serve basis)
How to order?
1) Reply this thread with the following information
a. Your name
b. Your contact number
c. Your local hobby shop name (LHS)
2) Contact your LHS and let them know your order
With these 2 steps, VXR Racing will follow up from there to make sure you receive the products.
It is a limited quantity offer. Get them NOW!
Get this FREE!
How to order?
a. Your name
#156
Originally Posted by VXR Racing I
Buy and
FREE !
How to order?
a. Your name
FREE !
How to order?
a. Your name
#157
Get this FREE!
How to order?
a. Your name
Get this FREE!
How to order?
a. Your name
1) Michael Ooi - 012-3682778 - RC Planet
2) Thompson Hong - 016-3091381 - RC Planet
#158
Article below taken from VXR Racing website: http://www.vxrracing.com/news/raja.htm
Kota Raja (Malaysia) 3 Hour Endurance Race - 1/10th GP Touring
Back to News Archive
Congratulations to Team Snake/VXR!
21st Oct 2005 - Team Snake/VXR consisted of Suah KH, Steven Tye, Andy Dass and Hafiz Junior running a Serpent 710 with an OS TR.12 were declared the champions in this grueling 3 hour race and were the only team to achieve 600 plus laps.
Powering the electronics on their car, the team used VXR Li-Po1050mAh pack and a VXR prototype switching 5amp regulator. This combination with a total weight of 60grams gave a whopping 1 hour 45 minutes runtime on a single charge. Two of these packs were mounted on the chassis and all it took to change the pack was a mere 5 seconds. A big advantage as opposed to pulling out the used pack and making a replacement.
This race shows that the 5amp regulator is bomb proof. What’s a 45min final when it can run a 3 hour enduro!
Another prototype that was used is the VXR 6mm Tuned Pipe – The ‘X1’. Consistent performance throughout the race and excellent power band for an OS 5 port engine was the comment by the team. The X1 pipe will be launched in November ’05.
Unleash the Power!
Unleash the Power!
#159
Hi There VXR I, pls check you signature.. you need to remove ./ at the end or user wont be directed to your url when clicking it.
#160
Thanks for the tips, I think I got it now!
Cheers!
#161
3) Yong - 016-6722151 - Nam Lee Hobby
It's moving. Reserve your quick!
#162
Get this FREE!
How to order?
a. Your name
Get this FREE!
How to order?
a. Your name
4) Baharudin - 012-3727722 - RC Planet
#163
5) Emeel - 0192801000 - HPC
6) Ikmal - 0122022502 - HPC
#164
7) Joshua - 012-9789889 - RC Planet
#165
ONLY RM199.00, this is what you get in the current promotion package.
