JConcepts Tyres and Products
#61
black jackets are designed for loose sandy conditions. these will be really good when the tracks has had no rain and is really dry. same selections on compound.
I used stackers in blue compound to win MNL4 in KL. I made the wrong choice though as it had rained before the final. green would have been faster.
the other #1 tire to have is the hybrid. I used this to win MNL 5 and also all 4 rounds of the southern series I race in. Even in green its last 60 min easily. its a great tire for grooved or loose conditions
best to mount these yourself as they are more readily available that way. harder to get pre mounts as they are always limited in supply form usa
#62
stackers are best used for hard packed clean surface where there is a nice groove. in terms of compound you want blue for all round conditions. if its been wet or you need more grip then green compound. the tire has a medium sized lug like an impact.
Boss, so will you be coming in premounts for the Stackers in Green and Blue compound?
#63
Bring a new set of wheels, foams and rims over if you are coming to Southern Series 1 and I will show you. I taught Didier at the beginning of the year and he could not believe how easy it is when you get shown the right way to do it.
Worth getting a bottle of JConcepts glue and also some extra JConcepts glue bottle straws. They are key to making your life easy in gluing up tires
#64
Gluing is super easy and quick to do. Im happy to show you the easy process and you will have a full set perfectly glued up in 5 min with no tools. Its something worth learning as pre mounts can be tough to get hold of. and you will want different inserts some times so being able to glue yourself is worth the effort to learn
#65
Will the tires arrive in time for the Southern Race? If so, I'll get 2 sets of soft Stackers. Pre-mounted if available. thanks.
#67
It's ok. I take a set of Stackers in soft with a set of yellow rims. U guys coming for Southern race? I'm Adric by the way.
#68
#69
Hi,
Is the backpack here?
#73
Did the shipment arrive? If so, please bring the tires if can to Southern. Thanks.
#74
I will not be joining the Southern Race this round.
