technical support and discuss for hobby wing product
#151
Hi all.. i just got confused when reading the hobbywing website...
I have a Xerun 120a esc v2.1+ 10.5 T sensored hobbywing motor.
Initially the software dont have boost function.
Will the new software will enable my ESC to have the boost function? or the software is not compatible with this esc and motor?
Im blur here...
Im blur here...
it depends on which software u installed into ur esc...try using da 522stock or v2.0_101101stock software...
btw,ull need a LCD prog box for u to link ur esc to the comp
#152
Thanks bro! received!
I will use with my program box.
#153
#154
what is the maximum and safe operating temperature for both the Xerun 120A esc and motor??
#155
#157
mnc is coming need to ask are the zero timing heat temperature are same as turbo timing with 10.5t must in currently 80deg 90 on danger side.or can i set to 90-100deg??any danger??
#158
Is 518 fast or 522? I using stock hw 10.5 turn.
Please recomend setting for 180 feet straight.
#160
#161
blue xerun 120a is abt rm450 while black is abt rm400
#162
hei guys..
my esc is flashing green interval of 1sec..
bt now im able to check the temp..
esc temp: 30-40 degrees
motor temp: 40-50 degrees
i've check all the connector n found no sign of shortage..
using FDR 8.13, motor rx1 11.5t
setting of xerun 120a
4) 8
9) 7
12) 6
13) 4
14) 5
15) 5
do any1 know what might be my prob??
4) 8
9) 7
12) 6
13) 4
14) 5
15) 5
#163
