Team Losi Malaysia News, Supports And Discussions
Hi All,
You are welcome to talk about the Team Losi Products here.
The LOSI GURU tips ADAM DRAKE.
How to prepare the body shell for hot weather.
http://www.youtube.com/watch?v=i0puA..._profilepage#!
How to rebuild the diff gear
http://www.youtube.com/watch?v=Jm7gQ...eature=related
How to Threadlocking the Centre Driveshaft
http://www.youtube.com/watch?v=3UdR5...eature=related
How to Adjusting the Ride Height of Your Vehicle
http://www.youtube.com/user/LosiRaci.../7/BWvdzIjiBvc
How to Adjusting the Camber on Your Vehicle
http://www.youtube.com/user/LosiRaci.../8/VjxxeJgrq5c
Suspension for losi 8 2.0.
wow losi thread ,
nice ,
ken sifu may i know what shock oil and piston you're using for taiping track?
shock oil brand also.
mine always become soft towards 10 mins of driving hard ...
thanks for sharing...
nice ,
wow,
so stiff oil but big piston hole that should do it for smooth track,
how about wheel base adjustment on rear spindle front and back spacing?
thanks for sharing
thanks for sharing
JVD Clutch System
Danny ,JVD clutch you are using is 4 pcs aluminium?
Pls PM me the JVD systems if available. Comes with multiple springs?
i see you use max shock oil 60 with std shock 54 piston nia, the track bumpy like penang?or smoother like taiping?
tq.
tq.
winde.....u should order shock oil 50 to 90 to give us to try it out!
Clutch from LKH.
It's a 4 clutch system same with LOSI and configuration like different spring can be use. It's same with Losi. I use JVD instead of the LOSI system cause I got used to it and like the the consistency of it.
Same same lah...........not much differences. I don't change my shock that much. Bumpy or flat.........I only adjust the pre-load or change the shock angle..............first and if no combination is found then only I change the oil. Minimum I use 600 or higher and no lower...........I like it hard..............
DT
DT
Its great to have LOSI thread here......
