RC Planet News
#256
Back In Stock Temp Gun..
Measurement range : -55~220°C ( -67~428°F)
Range Accuracy : (Tamb=23±3°C) ±2% of reading or 2°C (4°F) whichever is greater
Mode : Real Time Max/ Min, Lock, Clock, Stopwatch, Ambient Display
Battery : CR2032 x1 pc
#257
FX Engines Combo with FX Pipe set promo till Surabaya C-netic and MNL Rd5 Interested Racer please contact us at +6 03 5636 5163 or +6 012 280 8810 or +6 012 423 5837. Thanks...!!!
#258
#259
Ulti /racing tyre New stock arrived...!!!
1/10 Carbon Rim
1/8 On-Road carbon rim
for details please refer to: http://www.creationmodel.biz/ulti_top.html
1/10 Carbon Rim
#260
XRAY NT1 2013 Back in stock.....
#261
#262
#263
Back In Stock Savox SC-1251MG
New Savox Brushless 7.4v SB-2273SG (28kg/0.095sec) & SB2274SG (25kg/0.08sec)
#264
An alternative to commonly used motor spray or brake cleaner. This quality rechargeable canister gives a similar feel and result to motor spray during use, it can also be used with less toxic and more environmentally friendly chemicals. Other benefits are it's reduce cost by re filling and re charging it yourself. It is rechargeable with air safely up to 200psi using any standard car tire attachment and air hose. GRC 600 comes with 1 extra internal rebuild, 6 spray nozzles and 4 spray tubes. Recommended chemical for cleaning plastic is a diluted simple green/water mix. Recommended chemical for cleaning bearings and metal is denatured alcohol
Recommended for off road, rubber tire on road and tire rubber tire cleaning, LG1 comes bottled in a aluminum spray bottle
Recommended for foam tire asphalt, rubber tire TC, super grooved off road and long term tire conditioning
The new reformulated LGC. Improvements such as a Larger bottle, Better applicator, Lower odor and simply better performance are a few of its new quality's. The additive was developed on carpet to comply with tracks and organizations which use "odorless additive" BUT is already finding its way too many other tire and track applications, thus making it the most versatile additive in the "Liquid Gravity" family to date
This file is double sided with 80grit carbide abrasion on one side and 150 grit carbide abrasion on the other, anodized aluminum handle with lazer engraving, works great for filing or chamfering almost anything, as well as rounding foam tires
This 3mm punch is hand made by a racer out of hardned tool steel, this tool comes in handy to make a hole in your tires before or after mounting, while easily fitting into your tool box
These Titanium outer hinge Pins are designed to reduce the unsprung weight of the suspension at its greatest point of instance (outermost). They fit the T2,T3,T4 series XRAY Touring cars. The total weight of all 4 pins is 2.5grams. This makes for a unsprung weight savings of over 2 grams total or more than half of a gram per suspension corner
100% Polydimethylsiloxane fluid. This silicone is recommended in place of putty in front diffs of today's electric touring cars and other vehicles, through testing we feel like the performance and especially the consistency of this ultra thick silicone is a better solution than a spool or the commonly used putty method for front diffs
#266
Back In Stock..
PFR18 Lightweight
PFL128 Regular Weight
PFR18 Lightweight
#267
New Elan R Acdc Charger..
Charging Current 0.1 - 15 Amps (180w)
RCH 0.1 - 20Amps (230w)
Discharge 0.1 - 7Amps
Battery Support : Li-Po 1-6S, Li-Fe 1-6S, Li-Ion 1-6S, Ni-Mh 1-14S, Ni-Cd 1-14S, PB 2-20V
Usb Port 5v/1.5Amps
Usb Port 5v/1.5Amps
#268
New From Hiro Seiko 24k Gold Color Stainless Steel Screws..
Both button and flat heads available in 6,8,10,12,14,16,18 & 20mm
#269
New Graphite Arms For Xray T4 2014..
#270
Xray XB4 2014 Spec..
