XRAY NEWS
#691
High-dynamic Red clutch shoe
Small diameter
CNC-machined
Hard red clutch material
Less slippage and wear
Recommended for medium- and high-traction tracks
please check this out with your local LHS....Thanks...
#692
Dear NT1 kakis..... Alu Front Anti Roll Bar sudah sampai.....
#332401 Downstop Independent Alu Front Anti-roll Bar
alu front anti-roll bar
CNC-machined
independent downstop & bar adjustment
wheelbase adjustment via shims
The new aluminum front anti-roll bar for the XRAY NT1 allows you to independently adjust the anti-roll bar from downstop, so that the downstop setting does not influence the performance of the anti-roll bar and vice versa.
An added feature of this set is that you can also adjust the wheelbase. The anti-roll bar moves together with the front arm, and wheelbase adjustment shims can be added either in front of the anti-roll bar (to shorten the wheelbase) or behind the arm (to lengthen the wheelbase).
CNC-machined
#693
#330004 XRAY NT1 World Champion Limited Edition
XRAY is very proud to share with you the most exciting moments of the World Champion title.
The XRAY world-wide team has over the decade captured in different categories around the world more than 42 titles of US Champion, 13 titles of European Champion and 300+ National Champion titles. This year, Team XRAY adds to this extensive victory list the most coveted and most valuable title : WORLD CHAMPION!
Celebrate with us these wonderful and glorious moments, celebrate with us our first World's gold medal with the collectors' limited edition Ralph Burch NT1 World Champion Edition loaded with all the newest and finest option parts as used by the XRAY Factory Team and Ralph Burch to win the World's title.
33 0004 NT1 World's Specs:
33 1215 Graphite Upper Holder For Bumper
33 2401 Downstop Independent Alu Front Anti-roll Bar
33 5511 2-speed Shaft - Lightweight
33 5711 Front Middle Shaft - Lightweight
33 5250 Alu Wheel Hubs
33 5072 Lightweight Diff Outdrive Adapter - Short
33 5073 Lightweight Diff Outdrive Adapter - Long
33 5081 Alu Hardcoated Diff Pins
33 6155 Graphite Battery Plate
33 6231 Alu Radio Plate Mounts (L+R)
33 8716 Brass Engine Mount
33 4111 Ventilated Brake Disc
33 4141 Lightweight Brake Disk Adapter
33 5521 Lightweight Carrier For 2-speed Gear
33 5531 Lightweight Drive Flange
33 4061 Alu Brake Post Arm
XCA High-dynamic Clutch Set
33 8513 Lighweight Clutchbell
33 8532 Lightweight Flywheel
33 8561 Flyweight Set
33 8571 Clutch Disk
33 8578 Clutch Shoe - Red
Halo Kakis, NT1 WC Back in stock tapi limited units only.... please contact your local hobby shop as soon as possible.
Thank you
33 8571 Clutch Disk
Thank you
#694
33 8571 Clutch Disk
Thank you
33 8571 Clutch Disk
Thank you
#695
#696
#338716 Brass 1-Piece Engine Mount
Brass Engine Mount for NT1
Solid engine mounting
Easy adjustment
Stiffer design yet more flexible than the Multi-Flex 1-Piece Engine Mounting System (#338712)
Reduced chance of spur gear breakage/stripping
CNC-machined from premium brass material
Precision machined with highest tolerances
Ultra-strong construction provides very long life and durability in even the most extreme racing conditions.
Brass material is heavier by 26g then standard monoblock
More in-corner steering
#697
#698
#338690 Fuel Tank Capacity Sticker
fuel level indicator for XRAY fuel tank
white transparent die-cut sticker
displays fuel measurement in 5cl increments
set of 4
#699
Mike Swauger to Xray...
We heard some rumors about his departure from Mugen and today RCAmerica/Xray USA have announced the signing of Mike Swauger for the 2011 season. Mike is a World Champion, Multi-time Worlds finalist and has many National titles also. They are very excited with what Mike brings to the table for the 2011 season. Mike will be using the NT1 WE and the all new RX8 this season along with SRC 1/10 and 1/8 tires. The first race out for Mike will be the Winternats in Fort Myers FL and he will also be attending the up and coming 1/8 World Championship in Homestead, FL. Mike had this to say about the deal:
I would like to thank Mugen for the many years of support and wish them the best. I am really looking forward to this next year with RCAmerica/Xray USA. I feel that I will fit in well on the team with follow drivers like Ralph Burch and Paul Lemieux. This will be the start of one of the strongest teams in the US and I am very happy to be part of it. I will be helping Xray USA with R&D and some team management on the West coast. Thanks to everyone that has showed me support thru the years and I am proud to let everyone know that my new home is RCAmerica/Xray USA.
#700
Guest
Merry Christmas to all xray drivers and fans!!! be a good boy then Santa will visit u!!!
#701
Part xray NT1 sama tak dgn 2010??..bleh masuk??
salam racers sekalian..part NT1 2009 sama tak dgn 2010?...bleh pakai tak?thx for da info
#703
#704
#705
