New Products Lineup
#62
Re: Re: "NEW"Nitro TC3 Centax Clutch
well spawn, perhaps we could look at the positive angle, at the price stated.... could the stuff deliver the performance that you could edge out the rests of the guys???
just an opinion....
just an opinion....
Originally posted by spawn
Will probably be too bloody expensive when it comes here. If it is prices below 250 then can consider but where to get the pinions? should be expensive again!.
#63
Re: Re: Re: "NEW"Nitro TC3 Centax Clutch
just an opinion....
just an opinion....
#64
just an opinion....
just an opinion....
Unless of course if we are talking about world class level where the skill level of top ten drivers is on par to each other, every little advantage they can squeeze of of their equipment make a whole lot of difference. That is world class level of course.... But for the ordinary Joe like us, it just doesn't makes any difference. Might be a good idea to spend that amount of money somewhere else.
#65
People say shaft driven nitro cars do not need the Centax clutch. But what about LD3 and the Kyosho FW05R? Why do they come with Centax clutch?
#66
Re: Re: Re: Re: "NEW"Nitro TC3 Centax Clutch
No point having the most fanstastic clutch when you overshoot the corners every now and then.
#67
I have used std clutch and centax clutch, of course the centax is more efficient but I am not willing to spend that much money when my std clutch is working just as good. Funny thing is that once I have found the right adjustment for my centax I dont adjust it anymore although it is totally adjustable. I also found the right setting for the std clutch so I am happy with it.
#68
#69
Originally posted by InitialD
The thing is you run on the same track come every weekend. If you run on various tracks where traction can change, you need more slip in the clutch out of the corners to pull the car nicely. If traction is high, you can set the clutch to engage at an instant. So that's the "adjustable" thing about the Centax clutch.
#70
but I am too lazy to adjust coz I have to remove a lot of stuff to adjust it.
#71
No need to take out a lot of things... Just put in a 1.5 mm allen driver in one of the holes of the clutchbell. Find the goove of the retaining nut that sets the spring tension. Once you find the groove, stick the 1.5 mm intot he groove and lock it and turn the flywheel only. Clockwise to LOOSEN the clutch nut and anticlockwise to TIGHTEN it.
#72
Ya but for mugen I have to remove the brace, then remove the air filter then only can adjust.
#74
#75
Have you tried using the normal "L" shaped allen key instead of the straight driver type? Has seen one of my friend do it and it can be done without removing anything.
