All HPI RS4 3 post !!!!
#91
i would suggest the kyosho V-one-S.....becoz u said u wanted a kit right ? its a really good car for beginers the engine a powerful and its handles great !!!!
#92
Thanks littlewing
I'll survey that..
I'll survey that..
#93
does neone know where to buy hpi products in jb ??? thx.......
#95
LIVE FOR R/C !!!!!!
#96
The HPI RS4 3 can tahan turbo engines, wear and tear not so much of an issue, only car maybe bit more unwieldy...become car drive driver and not driver drive car !!
Also how to make that little box appear in my post which shows a previous post im replyin to ? No laughing please i am forum virgin !!
Any of you RS4 3 owners have problems wif the car bottoming out ? Especially when cornering , cause the car rolls quite a lot, swaybar also damn ineffective ! I've been experimenting with spacers outside the shock shaft to limit travel - like downstop i suppose. anyone have brighter ideas ?
#97
#98
#99
Originally posted by bodigat
What kind of engine you are running now in your rs4? Im using TT EVO + ported Nova carb right now and i have an issue for the rear final drive gear (the pinion and big cron gear) wearing off.
#100
Originally posted by InitialD
Perhaps the trick to longer lasting pinion and crown gear is to lube it. Use lubes like AE's stealth lube. They are very good.
BTW, on saturday i opened up the EVO engine and saw that the sleeve, piston and conrod are bigger than other 3 port .12 engine. Also the sleeve are ported a little bit.
Later that night while running the car at BKE with my friends the gear stripped. Also found out that the engine over heated really fast. After 5 laps or so the temp sky rocketed to 180++ celcius. I turn the HSN 3 turn but the engine still over heated. Maybe the carb is choke or something. The ingine is idling erratically.
#101
#102
Just buy a MUGEN la ... ok 705 pun boleh tahan~~~
#103
#104
Originally posted by x_man
Mugen is ok, but don't get the Serpent 705, i believe they are releasing a new tourer somewhere around the end of this year! a 710, call Hobbylink - Sam to confirm.
BTW, X-Man were you racing yest @ Today's Mart.
#105
Originally posted by Ravi Nair
Yeah the 710 should be release soon. According to Hobbylink the earliest it would be release in mid Dec.........
