Atria Car Park Speedway
#9121
Originally posted by tornado
Okey! like that got more sifus liao.
#9122
Originally posted by spawn
no problem but InitialD and Soulfree is better at diagnosing any engine problem.
Soulfree's car was like magnet and damn kow lan chat happening at TT yesterday. The modified 710 gearing on the 705 worked splendid. Only a front belt sapu prevented him from practising more.
But the Sabah guys driving 710 were really awesome. They really have firepower under their hood.
#9123
Originally posted by InitialD
Not so good at diagnosing my own engine.
#9124
Guest
Getting a GP car?
Getting a GP car?
Bryan
#9125
Guest
Re: Re: Re: Re: Racing Art Tire Truer - The Art of Racing
something wrong with the transmission lar!, anyway got the photo from tpracing.com
Bryan
#9126
Guest
Errrrr.....anyboli here know who is selling Corally stuff here huh ?
Bryan
Bryan
#9128
Uncle PINK must read!!!
ei, u want buy battery car or not??
uncle thomas say that he offer us the Hyper10 car...
then he also say that, if u play Hy, he also take a new 1 play together with us...(i also buy lah)
so how?? very cheap leh... u go 2 ask thomas how, ok...
if u only want play drift, just buy the cheap cheap 1 lah, so no need buy what the yokomo, tc3, hpi...
ei u no play car last sunday leh so few people only. if every sunday like that
NITRO car will cold down and die loh
#9129
#9130
hey hantu666, I have left the rtv silicon at HQ, go pick it up and return to me when you are done.
#9131
I wanna change gearing for andalas, so change pinion or spur? how many gigi recommended?
#9132
Changing pinion (to bigger size) has a bigger effect on gearing. Changing spur (to smaller size) would have a smaller effect. You also need to take into consideration the tire diameter.
#9133
What are you using currently? Stock gearing is just nice.
#9134
currently stock gearing, its OK...just that the engine screaming abit too loud once tire is about halfway thru. Might try with smaller spur first...
Say if you find that brand new 65 mm tires are perfect for the straights (engine wise) with stock 17/22 pinions and 60/56 spurs and you find that when the tire wears down to 62 mm, you need to change to a 23 pinion if you still want to use the 62 mm tires.
The 23 pinion and 62 mm tire will give you the same top speed and tire rollout as the 22 pinion with 65 mm tire.
#9135
Ummm, you can try the smaller spurs but it will not show any drastic effect...
