Help On Futaba 3pk
#61
Originally posted by x_man
Eh! Prof D, where is your Death Star Thingy!..........The Darkside! remember, THE DARK SIDE!!
#62
Damn...woke up this morning ready to kick ass and realised I had enough fuel only for 2 tanks...
#63
Damn you guys aeroplane me !!! I was the only one there !!
Crash, you could have borrowed some fuel from me for a few tanks... Don't worry, just replace me a brand new 2.5 liter tin Tornado fuel will do for me.
#64
#65
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
Re: 3PK?
Originally posted by morpheous
3PK? he he.. Aaaa.. you.... you know.. duhh!!..
Hey! How much haa?? Still using analog Futaba MJ. hehe.. Still a primary school boy.
mop
#66
Re: Re: 3PK?
Originally posted by mop_iko
its RMB1950 here in shanghai... about RM975... mahal or not? this price without servo la ....just want to ask to comapre la.... if mahal... (or even murah) dont order from me... hehehehe.
mop
mop
mop
#67
HOW LOW IS LOW for the voltage
anybody ... i need some input here...
i am using 3PK since few months ago (actually its my first RC). I am using 8 alkaline batteries (DURACELL sometimes GP Batteries). If i put the brand new batteries, the voltage is 12V. and the battery life going lower and lower as usual after sometime.
My question:
1ST QUESTION:
I want to know (the LOWEST VOLTAGE) when i should change the batteries. For my couple of battery packs before this, when it reach 9.6V i will change to a new pack. If i want to play with 9.6V pack can it be trusted to allow the TX to talk to the RX?
I asked this coz i still keep the previous packs that i have used before for my 3PK just incase i can use them again....
2ND QUESTION:
What is the different between FM and PCM? which one is better and why? I have 2nd hand RX FUTABA FP-R113F FM 40MHz... is the RX good or is it really an OLD MODEL?
thanks!
MOP
My question:
1ST QUESTION:
2ND QUESTION:
thanks!
MOP
#68
Re: HOW LOW IS LOW for the voltage
1ST QUESTION:
1ST QUESTION:
2ND QUESTION:
2ND QUESTION:
The only way to test your old R113F receiver is to test it out.
I have the R123F receiver from my old 3PDF controller. I can use this receiver with the 3PK Tx but I need to change the mode to PPM / FM in order to make it work which does not support fail safe mode.
#69
311IP with 27mhz short crystal
somebody want to sell his RX and TX to me for my 3PK.
the model is FUTL0300 R113IP
3 channel PCM
27Mhz with short crystal.
Is this Rx and TX good?
what is the different between short crystal and normal crystal?
another question:
if 3PK have built in fail safe function.... can i use FM RX and TX (which dont have fail safe feature).... and set my 3PK to send fail safe signal to the FM RX if low voltage or loss connection occurs?
thanks!
mop
3 channel PCM
another question:
thanks!
mop
#70
Re: 311IP with 27mhz short crystal
What cyrstal are you using now? 40 MHz? Better save and get spare 40 MHz crystals. Just get another 40 Mhz Rx receiver module for the other car. No need to get another Tx module.
Even if you have a HRS/PCM receiver (not ordinary FM type) and choose to use PPM modulation instead (not PCM or HRS modulation), you cannot activate the fail safe features from the 3PK. In short, you have to have HRS/PCM receiver and use PCM/HRS modulation in order to use the fail safe features.
#71
Re: Re: 311IP with 27mhz short crystal
You mean you are offered the 27 MHz Rx receiver and the Tx module for the 3PK? Why go with 27 MHz? You'll end up glitching with the other RTR cars !
SHORT CRYSTAL.... i dont know... but that is what being SHOWN in FUTABA website... this RX 311IP comes with 2 types of crystal... short crsytal for 27Mhz and normal crystal for 75MHz... that is why i want to know what is the different between short crystal and normal crystal... something new to you huh Master D?
mop
#72
Re: Re: Re: 311IP with 27mhz short crystal
actually i am using 29Mhz currently for my 3PK (comes with it when i bought it)... i know 29Mhz is kind of funny frequency. I have read it somewhere in the thread. But so far i have no problem using the 29Mhz.
The 40Mhz RX i have came with the TC3 i bought for 2nd hand... but i dont have TX module for 40Mhz.. maybe i need to think more how to make use of the existing 40Mhz Rx that i have. Like you said better use it and just buy another 40Mhz TX module for my 3PK since the RX is FM (which is faster respond compared to PCM.... but no fail safe... a DOWNSIDE of it... ARRRGGGHHH need to think of it again la... slow slow think... no rush...
Second option is to get another PCM or HRS 29MHz Rx. That way, you can use your existing Tx module. You get all the bells and whistles of the 3PK this way like the full feature fail safe !!
For me, I'll go for the 2nd option.
#73
Re: Re: Re: Re: 311IP with 27mhz short crystal
if i have 29Mhz for my TX in 3PK.... can i go for ANY 29Mhz right? as long it is 29.xxx Mhz...right? at least i have 2 types of 29Mhz.... no need to be same as my current 29.xxx Mhz right?
mop
#74
Re: Re: Re: Re: Re: 311IP with 27mhz short crystal
hey! actually i am thinking the same way right now... THANKS for showing the LIGHT to the DARK SIDE....
Just a thought... If you get the HRS/PCM Rx alone, you will only be provided with a single crystal for the Rx. No crystal for your Tx. So my guess is that you better specify the same crystal on the Rx as what you have now when you make your order. That way, you do not have to buy separate pair of 29 MHz crystals.
Else if you want another set of different 29 MHz crystals than what you're having now for backup and kiasu sake, then get a separate 29 MHz crystal set...
#75
Re: Re: Re: Re: Re: Re: 311IP with 27mhz short crystal
Great minds think alike? Eh mop, how can you see light in the darkside? Are you sure you're in the darkside and not somewhere else halfway?
mop
