E Crawler
#31
#33
#37
My AX10-Demon's Rock Chassis
I decided to ditch the X-trail chassis and came out with this. I called it Demon's Rock chassis. It's CNC cut from 3mm 6061 alloy.
Links will be modified. The skid plate will be milled from delrin and the linkage will be triangulated to gives better stabilization. I am running a droop configuration shock with internal springs. Servo will use the Hitec HSR-5995TG, Mamba Max esc with Team Atlas 80T motor. The tire mounted on the bead lock is the Proline Masher. Wheel base is adjustable from 12" to 13"
The built will take a while to finish as I am waiting for the servo to arrive.
#38
#42
Tamiya crawler
salam sejahtera semua
over the weekend try slow2 pasang Tamiya land cruiser cr-01 crawler...baru sampai takat ini saja. Tayar pun pinjam Willy sebab kit punya belum sempat pasang. 80 skru o!
interesting chassis, dgn planetary gear, etc.
