E Crawler
#196
chun aa...waiting u aaa..hehe
#198
Guys,
This machine is on it's way to invade Malaysia... book yours now before it's too late... available from RC Connection and HPC at Glenmarie. Go there and see it with your own eyes... Full alloy axle with alloy beadlockers....
pictures taken at HPC
From the manufacturer website..
#199
...A little too tall IMO the chassis, and the front bumper frame can get hooked up on the rocks easily with wide axles. Lower CG would be good.
But overall nice, i like the axles they look good
#201
New Crawler from YOKOMO...
The main specification
- 4WD full-time twin motor gear down system
- Twin motor attachment with torque ring
- Long stroke made of resin damper
- Three bead lock type piece wheel
- Soft compound crawling tire
- Ben dead trailing arm
- The back and forth solid axle
- Full ball bearing
- For two servo type 4WS
- Body made of polycarbonate that has been painted
- Full ball bearing
#202
Wow!! Kenny, i like your Safari-style bodyshell... looks very cute... haa!!!
Aiks!! what happenned to the Rock Lizards & its beadlock? They went on to the CR-01 ?
#207
ehhh... what happened to PSC? ... so you gonna braze it or bolt on?
If you wanna braze it... I suggest you try on the actual rod size that you wanna use to test if your torch is capable or not. .. it's because alluminum is a good heat conductor... so, the heat may be dissipated faster and the torch may not be "powderful" enuff..... kalau ada TIG set lagi bagus laa..... need to find if d.i.y TIG is around...
My PSC is at 50% stage..... if can,will post pics later...
#209
Speed,
dont poison me.. poison spyder is indeed poisonous!
For the last pic, if I do propotional comparison of the tire diameter and the tube diameter of this real crawler, to compare to rc crawler that uses 2.2 Rock Crusher (140mm), then the tube diameter should be around 4.6mm.. how? Understand my england kah?
#210
ha ha ha.... why worry??? in fact, it is very poisonous.... and I am already poisoned.... well, I understand your british... so, since you already have the scaling, there is a 4.6mm (around that) tube... it's stainless steel lah..... but, the SS brazing rod that I bought yesterday, when I tried to brazed it on the SS rod, hancusssss!!! Butane, Propane, MAPP?????? tak bleh pakai... have to use Oxy Acetalyne la bro.... or maybe Oxy Propane...
