Buggy Steering Servo Horn.
Trader Rating: 45 (98%+)
Hi all, need servey/ know what servo horn that you use on your buggy steering. You use plastic or aluminium? Mine look like the horn strip from servo when I bang to tire.........lastly found that the servo horn strip. I try to hole the servo horn and turn the wheel and I can feel it strip. I also may suspect I using wrong type/ different brand servo horn and it can't fit smoothly. Before get new I need advise from you guy which is recommaded, plastic or aluminium. Thanks.
Hi, thanks for the reply. May I know that for my case the horn strip mean I use wrong type of horn? If same brand it should easy with little force, right? MAy I know the cost for one pcs is how much? Thanks.
Thanks for your reply again. Ok, I get same brand horn...
Hi JSA, may I know your shop got fully aluminium horn for hitec servo? I am using high torque servo which is 645MG. This is for my buggy steering. Pm me the price.
Imagine this, your buggy takes a hard landing and your sevo saver maxed out thus transfering the force of impact to your metal servo arm, metal to metal has better grip than metal to plastic.
When the force of impact hits and transfers to the servo arm do you think your metal gear wont be affected somehow or another?
With plastic arm the impact would have a better chance of striping the 'teeth' or deformation of the servo arm but preserving the servo.
The only plus point with an alloy arm is its heat dissipation values but weights more than plastic for sure.
That is why cars these days have crumple zones to protect it's occupant.
nothing wrong on your teoritical points........ but experience have proven for us to use the aluminium horn is better than plastic......horn=alu. but gear made by hard metal.
when impact 2x or 3x greater than the servo torque then only will strip the horn 1st then the gear
we always recommend to use Acer servo 1015, the best high torque servo in the market.......................
tkhoo,
we don't have the alu horn for hitec but for KO/Sanwa and futaba only.........
tkhoo,
But I need to know most race driver is running plastic or aluminium horn? thanks.
I'm no race driver, but i'm using plastic horn. and, isn't the servo saver suppose to do the job? by preventing gears strip?
tkhoo,
tkhoo,
Acer or Ace Racing Master JSA ?
