[WTS] Hobbywing XERUN V10 G2 Brushless Motor (13.5T) offer is back !!
Hobbywing limited offer is back !!
Limited stock available stock !!
First come first serve !!
Ready stock !!
Kindly whatsapp us for more information
Pennmart contact:
RC World 0125521788 (whatsapp)
Candy 0194633888 (whatsapp)
Address:
Penn-Mart Toys (M) Sdn Bhd
No 106, Jalan Raja Laut, 50350 Kuala Lumpur.
Tel: 603-26920725
Hobbywing XERUN V10 G2 Competition Modified Brushless Motor (13.5T)
Promotion Price: RM220.00 only !! (NP: RM380)
Xerun V10 G2 Motors
Specifically designed for extreme running in top 1/10 and 1/12 scale competition racing, the V10 G2 series motors and are compliant with ROAR, IFMAR, BRCA and JMRCA rules. They featuring the perfect combination of high quality materials, exquisite craftsmanship and cutting edge technology, the V10 G2 series provide the extra advantage all professional racers are looking for with minimal maintenance required.
Features:
kV: 3000
Resistance: 0.0265 Ohm
Current w/o Load: 1.8A
Max Output Power: 220
Current @ Max Output Power: 59A
Can Diameter: 36mm
Can Length: 52.5mm
Shaft Diameter: 3.175mm
Shaft Length: 14.6mm
Weight: 172g
Rotor: Φ7-12.5
Ready stock !!
Pennmart contact:
Address:
Tel: 603-26920725
Xerun V10 G2 Motors
Features:
- Designed to withstand extreme levels of use at its highest peak performance
- Complete CNC cut motor case with extra front spoke ventilation slots
- Works as a sensored motor and also sensorless without the use sensor cable attached
- Multiple steps of mechanical time adjustment from 20 to 50 degrees
- Minimal maintenance is required with precise machining technology which ensures a minimum tolerance end play of the rotor shaft. Eliminating the copper shims used in most motors.
- 200°C high temperature tolerance and high purity copper windings maximize conductivity and reliability
- 200°C high temperature tolerance sintered NdFeb (Neodymium, 35EH-LT) magnets
- Extreme low resistance multi-layered outlet PCB and high RPM NSK bearings
- Compliant with ROAR, IFMAR, BRCA and JMRCA rules
- Certified by RoHS, CE, FCC
kV: 3000
Can Diameter: 36mm
Can Length: 52.5mm
Weight: 172g
Rotor: Φ7-12.5
