OSRC ONROAD Carpet Racing Gautier MS
OSRC carpet race schedule for the rest of 2016:
June 11
July 9, 10. Trophy race
August. 13
September open
October 8 Trophy race
November 12
December open
Location is:
Duo Dance Event Center
3100 Ladnier Rd
Gautier MS 39553
June 11
August. 13
September open
November 12
December open
Location is:
3100 Ladnier Rd
Gautier MS 39553
Is this an indoor racetrack?
Mississippi Gulf Coast R/C Raceway
Touring
• 17.5 Touring Sedan
o 17.5 Roar legal brushless motor (D3.5 is also legal)
o Blinky ESC
o Rubber tires 24mm or 26mm
o 2 cell 7.4 battery
o GBS body rules 190mm
o Rear wing no higher than roof line or wider than car
o 4mm ride height
o 1380 grams weight
o 5 min heats and mains
• USGT Touring Sedan
o 21.5 Roar legal brushless motor
o Blinky ESC
o Ride / Gravity Spec tire or HPI X Patterns
o 24mm or 26mm spoke rims. NO dish wheels
o USGT Body 190 or 200mm body. NO Touring, WGT, Vans, SUV, etc.
o 5mm ride height
o 1380 grams (4wd) 1200 grams (2wd) weight
o 6 min heats and 8 min mains
• VTA Sedan
o Novak 25.5 brushless motor, Team Scream 25.5, Motiv 25.5, any Roar approved 25.5
o Blinky ESC
o 2 cell 7.4 5000 MAH limit battery
o VTA wheels and tires 26mm fronts #4793 and 31mm rears #4797 stock inserts. No tread rule. No sanding of tires.
o Vintage Body (driver figure is optional)
o 5mm ride height
o 1450 grams weight
o 5 min heats (gang starts) and 8 min REVERSE mains
• F1
o 25.5 2 cell 7.4 battery
o Blinky ESC
o Open F1 rubber tires
o Molded wings
o 3mm ride height
o 190mm width
o 1050 grams weight
o Hard plastic wing (No Lexan)
• 12th Scale
o 13.5 Roar legal brushless motors (D3.5 legal)
o 1 cell 3.7 battery
o Blinky ESC
o Foam tires
o GTP style body
o 3mm ride height
o 730 grams weight
o 8 min heats and main
• WGT
o Blinky ESC
o WGT Spec tires
o Standard WGT body
o 104mm body height
o 4mm ride height
o 930 grams weight
Oval
• 13.5 Pro Oval
o 1/10 Pan oval car
o 13.5 Brushless motor
o Open ESC
o Open foam tires
o 200mm Nascar oval body. Rear wing allowed
o 4mm ride height, 4 ¼ roof height
o 36 oz, 1020.583 grams, 2.25 pounds weight
• 17.5 Truck Oval
o 1/10 pan oval car
o 17.5 tour brushless motor (D3.5 legal)
o Blinky ESC
o Spec WGT tires
o 200mm truck body, 2” rear spoiler. NO side dams. Back of body left in.
o 4mm ride height, 4 ⅜ roof height
• 21.5 Sportsman Oval
o 1/10 pan oval car
o 21.5 brushless motor
o Blinky ESC
o Open foam tires
o 200mm Nascar oval body: 1.5” spoiler, back of body left in, NO rear wing. 4 ¼” roof height
o 200mm truck body: 2” spoiler, back of body left in. 4 ⅜” roof height
o 4mm ride height
• SK Modified
o 1/10 SK pan oval car
o 17.5 brushless motor
o Blinky ESC
o Open tires
o SK body
o 3mm ride height
o 33 oz, 935.534 grams, 2.062 pounds weight
o SK-KAR National Rules
• Legend
o RJ speed, Bolink legend car: Bearings, turnbuckles, and servo mounts allowed
o 20t Dynamite brushed motor
o 48 pitch 81 spur: 21 or 22 pinion gear
o Brushed ESC
o Spec WGT tires
o 1800 nicad battery
o Legend body
o 4mm ride height
o 34 oz weight
• Stadium Truck Oval
o 2wd 1/10 stadium truck
o 10.5 brushless motor
o 2 cell 7.4 lipo
o Open ESC
o Slick stadium truck tires. Panthers and Primes
• Mudd Boss
o Traxxas 2wd slash or raptor: Traxxas Low CG chassis is allowed
o Original MFG parts only. NO aftermarket hop-ups, no aluminum parts
o Front bumper must be removed, side bumpers can be removed if desired
o Traxxas front optional (tra2735) can be used (angled down)
o NO alterations to the chassis (such as holes, or removal of material)
o Front body post brace MUST be removed
o 13.5 Roar legal brushless motor (D3.5 legal)
o Spec ESC (NO TIMING OPTION POSSIBLE)
o Traxxas 2075 and Savox SC-0252
o 2 cell 7.4 5200mah 50c battery
o 76/83/86/90 spurs only, any pinion
o NO modification can be made to the transfer case
o You are allowed to move the wheel spacers with any combination or both
o Tranny Functionality Rule (motor cannot spin while turning one rear wheel)
o Original shock and springs only (NO LCG kit springs or aftermarket springs)
o Front springs may be cut to shorten them. Shock travel may be shortened with internal shim fuel tubing
o Original pistons from kit only, NO modifications can be made to them
o Mudd Boss Jaco foam tires
• Pancar Busch Series
o Any 1/10 pancar
o Any NASCAR body
o Purple or Yellow WGT spec tires
o RJ speed red front springs
o 81 tooth 48 pitch spur gear
o 20t - 26t pinion
o Duratrax 1800nicd battery
o Photon2 motor
o Any springs in center and side shocks
o Back of the body can be cut out
o Wings are optional
o 4mm ride height
o 38 oz weight
o Tech: Checking batteries and motors to see if they have been opened
• Blinky Buster
o Anything over a 2.1 will be illegal and considered boosted
• LIPO Rule
o Touring
1S max voltage is 4.20
2S max voltage is 8.40
90 degree max temp rule to race
o Oval
1S max voltage is 4.22 if over you must bleed to 4.20 to race
Mudd Boss 8.44 max bleed to 8.40 if over
Touring
o Blinky ESC
o 4mm ride height
o 1380 grams weight
o Blinky ESC
o 5mm ride height
• VTA Sedan
o Blinky ESC
o 5mm ride height
o 1450 grams weight
• F1
o Blinky ESC
o Molded wings
o 3mm ride height
o 190mm width
o 1050 grams weight
• 12th Scale
o Blinky ESC
o Foam tires
o GTP style body
o 3mm ride height
o 730 grams weight
• WGT
o Blinky ESC
o WGT Spec tires
o Standard WGT body
o 104mm body height
o 4mm ride height
o 930 grams weight
Oval
• 13.5 Pro Oval
o 1/10 Pan oval car
o Open ESC
o Open foam tires
• 17.5 Truck Oval
o 1/10 pan oval car
o Blinky ESC
o Spec WGT tires
o 1/10 pan oval car
o Blinky ESC
o Open foam tires
o 4mm ride height
• SK Modified
o Blinky ESC
o Open tires
o SK body
o 3mm ride height
• Legend
o Brushed ESC
o Spec WGT tires
o Legend body
o 4mm ride height
o 34 oz weight
o 2 cell 7.4 lipo
o Open ESC
• Mudd Boss
o Any 1/10 pancar
o Any NASCAR body
o 20t - 26t pinion
o Photon2 motor
o 4mm ride height
o 38 oz weight
• Blinky Buster
• LIPO Rule
o Touring
o Oval
I will be there! See you guys there. For those that don't know, this is inside a nice and cold skating rink so the subfloor is the rink. Which is smooth. The carpet is laid down over that and traction is awesome. Jaime puts on a good program. Hell, I am driving from Houston to race here this weekend if that tells you anything. Should be a blast.
There is a facebook group here for the track. https://www.facebook.com/groups/1104946326207137/
