HK Talk Version 1.1
Originally posted by Mingfinity
Any comment on the new Reedy Kr?
that Quad magnet design seems will decrease the back EMF.. so less drag brake!
Used the same winding configuration on a 'Ti' can and on a 'Kr' can (12x3 with the same thickness of strands) and the Ti is more temperamental. Ratios change a little needing the Kr a little more pinion and holds better the insane ratios that we use usually.
SAT PYC or EGR ?
DTM SAT go where ?
Regional Moderator
Originally posted by dtm
Just remembered...if you want high rpm motor, then try a Yokomo m/c wound can, 1.5 large graduations on timing, 140 deg springs with GM 03. My 9x2T Corally likes this combination in a Mirage Radix can...which is basically a Yok m/c can! Not quite as high rpm has old Yok black can....but better torque!
Re: Re: Re: Re: Re: Re: Something noticeable from RC World...
Alternative is to simply use 9A charge! hehe.......
the best way to make the car fast is mix things together,
all 6 cells different in a pack is the best.
Re: Re: Re: Re: Re: Re: Re: Something noticeable from RC World...
Originally posted by PeterCheung
u forgot what the 'master' says,
Re: SAT PYC or EGR ?
Originally posted by LeoChan
DTM SAT go where ?
DTM SAT go where ?
Originally posted by fai
Dtm: What's a m/c can?? The one came from S-World?? I don't have a Corally one so really have to think about yokomo cans... maybe the black one (S-Zero)...
Actually if you have a Yok Tmax stock....replace the bushing with bearing...this can is very high rpm!!
Re: Re: Re: Re: Re: Re: Re: Re: Something noticeable from RC World...
1700 Sanyo, 2000 Sanyo, 3000 SMH, 3000 UMH, 3000 HV, 3300 GP.......that should do it!!!!
Soldered with 5 different battery bars (Orion, Trinity, GPM <-- this one works best, Speedmind, er... i can remember that much brands) and 2 different banana plugs (Trinity, Team Orion)
Back to topic... How can you test different setting with different setting on EACH corner? The car can't even go straight to give you the feeling!
so the pack will punchy as 1700 and high capacity as 3300~wakakakaka
Re: Re: Re: Re: Re: Re: Re: Re: Re: Something noticeable from RC World...
yeah
yeah
eh..
what about 2400..
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Something noticeable from RC World...
I can't remember.. but I think the 3300 or SMH already as punch as 1700 already
eh..
what about 2400..
eh..
what about 2400..
need to ask dtm about this
DTM :
Jong Sau Lo SAT can't go to PYC die
Re: Re: SAT PYC or EGR ?
PYC......Jong Sau Lo is dead........the CCTs have arrived!!!
