HK Talk Version 1.1
Hi,
I am new to 23T. The motor is very very very hot after run, is it normal ?? Will it harmful to the comm, rotor or the motor itself ??
Thanks.
Thanks.
Originally posted by Anthony Yuen
Hi,
Thanks.
Hi,
Thanks.
improper gearing will make the motor very very hot ! check your brushes and see if the end that contact with the comm has changed color.
either too much under gear or over gear will cause this problem.
Here is the photo. Wear is not too much but color has changed.
Sorry, Photo is here.
Here is a zoom in of photo.
Definitely too much burn. Improper gear ratio. 23T should be geared at around 5 or 6.
Originally posted by TRF-Powered
HI,
anyone here know how much those tamiya tRF tool set and set up board cost in HK??? Thank you for any reply.
HI,
Hi,
Thanks.
Hi,
Thanks.
Originally posted by Mingfinity
Saw the TRF Wrench set today.. 480 HKD (includes 6 to 8 wrenches.. forgot)
Regional Moderator
I use 5.2 @ EGR
Speed and power is OK, but my skill and my tuning make me can't follow those PRO in the 'twisty' region
Originally posted by dtm
What are your brushes like??
Please find the photo for the contact surface .....
and the brush body. It looks like there is some decoloration by high temp.
