HK Talk Version 1.1
#8836
Originally posted by Manticore
Look at all of us diehard Ass o fans!!! we are seizing their springs all over MK !!
Still don't know if these 'green' springs are going to be any good!!
#8837
Originally posted by dtm
No there are lock screws.....it should work fine!!!!!! KY just forgot to put the second lock screw into the diff.......but thats not a surprise....because he never reads the instructions!!!!!!
#8838
They want you to "show" your F1 rather then "run" it !
#8839
Certainly won't be the first time that ernestf has done that!!!!! and probably won't be the last!!!!!!
#8840
you still need to work on the diff ring slippery !
#8841
I didnt say anything to this !!!!
#8842
Re: Re: Thanks DTM...
I don't know if you are allowed to do it in the Tamiya races .....but if you are, I would seriously consider cutting out some cooling holes in the chassis for cooling.......looking at my friends car it gets really HOT!!!!
#8843
Yes....I don't understand why they say apply grease on both sides of the diff plates....it doesn't work for the 201 diffs because there is not slot to reduce the surface area on the outdrivers....only results in the thing slipping more.....I use ASSC thread lock instead!!!!
#8844
Re: Re: Re: Thanks DTM...
Originally posted by Tommi Makkinen
I heard during the Tamiya World Championship they let you cut holes in the chassis and gearbox because the minimum weight rules in japan are lower than what we run in the TAC...
#8846
We know what you meant.....you just forgot to type 'again' after your sentence!!!!!!
#8847
#8848
Tamiya just copied the instruction book from Ass o ! Hurray Ass O !!!!!
Also the screws are everywhere.....the lock screws for the diff were in a different bag to the other screws for the diff...took me ages to find it...it was packed with the wheel nuts!!!!!!!
#8849
Originally posted by ernestf
should i use the yellow-glue to glue the outdrive and the ring together ?
#8850
