HK Talk Version 1.1
#7246
Originally posted by Disaster999
ok...ppl..i need help..the stock clutch is driving my crazy...it cant fit it on the engine....the gears wont run freely!!
anyone could help?
anyone could help?
#7248
the stock engine clutch.....for v1rr...
#7249
Regional Moderator
Originally posted by Manticore
you need to shim between the clutch nut and the inner bearing so that the clutch bell may spin freely when you hold the engine with the clutch bell pointing upward. initial setting of the clutch spring is that you may see around 1mm thread from the clutch nut.
#7253
thats the problem..i couldnt get the inner bearing into the clutch bell..i have to add another bearing (or bearing width) shim to fit the bearing into the bell...
When you put the Thrust bearing set with the nut, there should be some "Small shims" (diameter as the shaft end) and larger shims (size as the thrust washer) to adjust the bell housing.
#7254
tell him to get another one then..hahaha!!
#7255
regular price of F201 will be around 7-800 HK$ here
Ah "Q" Spirit RULES..
#7258
Re: F201
Originally posted by ernestf
I would rather wait for the stocks to arrive and at least some hopups available before I go for the car.
Flying price is really BS in such economics condition.
seems that many ppl interested in this car......
last time i saw one after u left...
very beautiful car...
#7260
Re: Re: Re: F201
how the car perform on track ?
