Race World Hawaii - Electric On Road
#496
I thought you still had 1 day left on those tires...mine are still trued and waiting from the last race.
I'm going to order some tires this weekend...need to get another set of F1 tires too.
#497
so for now I have
rear: Pink and magenta
front: magenta
any other compounds to bring up with me? I'm thinking a set of dbl pink front and rear also. What you think?
#498
#499
#500
I do but they are really in nice condition. Most likely bring that set, up with up with me to Vegas. Ill most likely race 1/12 the next race since I'm putting in a parts order for 1/12 ie. chassis plates, springs, tires etc...
so for now I have
front: magenta
so for now I have
front: magenta
#501
Would gluing the outer edge help the foam from separating from the wheel?
#502
Ok gang, looks like we are gonna meet at 8at Denny's kunia. And then to the track.
#504
Well just finished up 2 WGT cars for tomorrow...1 more to go.
#505
#506
im assuming the sidewall not the contact patch right? is there a special glue, or ca would be fine. I was thinking also, wouldn't rounding the edges of the tire steeper lessen traction roll? lol hard to believe 1/12 would since its soo low to the ground.
#507
Yes you want to round the edges even with CA on the sidewalls. On carpet the sidewall flex can dig in and cause even a 1/12th to traction roll but more likely the WGT since the minimum ride height is higher on WGT and the CG is also higher do to the taller bodies. Lately 1/12th drivers have been using CA less but I think that is largely because they are cutting the tires down even further.
#508
Great fun out there today guys! So good to see new racers and new classes out there. WGT was a blast with some really close racing. That series is going to be a close one! Gettin close to Goot's fast lap time in 1/12th too...got down to a 12.55 in the main
Thanks to the regulars for being so patient...between me running 2 classes and trying to help out with the new class and the new drivers things ran a tad later than scheduled. But not by much Thanks to everyone who helped out with the setup and take down today! Wes for vaccuuming the whole track and Danny for both setting up and taking down the computer and lap counting equipment, and Bob and Danny for stepping in and running a few heats for me while I was racing or wrenching. All that help made things much easier for me to keep things running smoothly all day.
Results are posted!
http://www.hawaiitalks.net/race-worl...er-series.html
Results are posted!
#509
For anyone else interested in WGT the general rules are:
1s LiPo
13.5 motor
Blinky ESC
WGT Spec tires: Jaco WGT Spec Lilac tire, BSR/CRC WGT Spec Lilac tire
WGT Body: 200mm body, front engine, rear wheel drive, GT class body. The ROAR rules only list the DB9, Sophia, and the Giana, as legal bodies but in the past the Corvette has been allowed. Others may be allowed if they fit the rules description. Please contact me if you want to run something other than what is listed so I can verify it before you spend money on it.
1s LiPo
13.5 motor
Blinky ESC
#510
Thanks IG and everyone at race world hawaii its always a pleasure racing with u guys...
