Wiregrass Indoor Nationals - who is in?
I mentioned this on Sunday, here is the info.
Wiregrass Indoor Nationals - August 6-8, 2010 Ozark, AL
Looks like the 2wd SCT "Limited" class fits the TT SCT class!
1/10th Scale Limited 2WD CORR Truck Class(electric)
* Any 1/10 2wd truck that is available to the public and made as a "CORR"
* type truck allowed(Traxxas Slash, HPI Blitz, AE SC10, Losi Strike, Etc)
* Must use either stock body or aftermarket body designed for truck. Added
* wings are not allowed.
* Tire/rim combination must be 3.0” inside bead diameter x 2.2″ outside bead
* diameter. Any tire marketed for the Short Course Trucks. No cutting/making
* tires. 1/8 or 1/10 Scale rims/tires NOT allowed. Tires/wheels must remain in
* stock form, zero modifications allowed.
* Batteries allowed will be either one 7.2 volt(6cell) nicad/nimh or one 2s 7.4
* volt lipo battery. No mah limit.
* Motor: Stock Kit motors or 13.5 Brushless. Must be available to the public.
* Chassis: Must remain in stock form, no modifications(Length, width, etc)
* Must be 2wd and may use ball or gear differentials.
1/10th Scale Open 4WD CORR Truck Class(electric):
* Any 1/10 4wd truck that is available to the public and made as a "CORR"
* type truck allowed(Traxxas Slash, Hyper 10SC, Jammin SCRT10, Etc)
* Motor: No motor limit Brushless. Must be available to the public.
Slash Spec. Short Course Truck Scale: 1/10th
* Slash 2WD Short Course Trucks Only
* Must use either stock body or aftermarket body designed for trucks. Added
* wings are not allowed. (No Beetles)
Ø Both the front & the rear suspension systems must remain in stock form. Original parts only. No aftermarket/Hop up replacement components may be installed. Box Stock Shocks, NO Big Bore. Aluminum Shock caps are legal.
Ø Direct replacement parts are allowed. For instance if RPM makes it for the Slash it is allowed. Ball Differentials are NOT permitted in the Spec Class. No performance upgrade parts. The part must be a direct replacement part for the Slash.
Ø No modifications may be made to the steering system. Original Kit parts only.
Ø Original Kit electronics Speed Control & Servo only. Traxxas – 2075. You may install any Receiver you so choose. On board traction/drift device or Gyro’s NOT permitted.
* Motor: Stock Traxxas Titan 12T R/C motor550.
Other nitro & 1/8 e-buggy classes, just posted the SCT rules. See site for details.
http://2010wiregrassindoornats.com/default.aspx
http://events.rcsignup.com/events/di...nt.cfm?ID=1097
I heard about this race last year. Gotta make it this year. Should be alot of fun! We should get a good group to go down for this one.
Steve
Steve
That sounds like a bunch of fun. We'll have to wait and see if Gene gets his SCT and has it up and going by then. I'm sure he will have a hankering for a big race and may close down shop for that weekend so we can go, then again he may not. If he does though I am game and we can probobly have a car pool (or a couple) leaving from TT so you have a safe place to leave your vehicle regardless of weather we run or not
Steve
Sounds fun lets did it.
Im in... I should have a truck by then however not crazy about the 20 min thing. Running 2 different 10 min would be ok with cool down time.
Will there be paid turn marshals?
