ATTOP A7, Mini hexacopter, XTop Flyer.
DRONE attop A7, Mini Hexacopter incredibly stable, X Top Flyer, a Hexacopter of this brand, the first thing I try and really liked it, perfect for flying indoors for its great stability and handling drone, which can also fly outdoors because their size is not as small as other minidrones can see us perfectly at distances of ten to fifteen meters, fighting well against breezes air and with a perfect speed contained for perfect control, this drone has a twist on its axis pretty good allowing us to make very good flight, definitely a drone echo to withstand shock and which we will enjoy a very stable and light flying. Being able to fly inverted mode, this drone brings a battery of 3.7 v 300 mah which gives us about 7 to 8 minutes flight.
buy in gearbest
Description:
The Hexacopter can do 360-degree turnaround and flips 180 degrees to inverted flight
Headless mode:
Just control the transmitter, the mode Hexacopter can fly without head forward, backward, turn left, turn right, there is no need to worry about it loses control because there is no sense of his head.
6-axis gyroscope and position control system:
This feature Hexacopter has stable flight and easy operation.
Lock mode route:
The button can lock the direction of flight, regardless of the direction pointing head.
modular structure:
It is easy to install and easy to disassemble for repair.
Budget:
- Model: A7 attop
- Charging time: about 50 minutes
- Flying time: 5 to 6 minutes
- Frequency: 2.4 GHz
- Gyro: 6-Axis
- Flight Battery: 3.7V 300mAh Li-Po battery
- From the transmitter battery: 3 x 1.5V AAA batteries (not included)
Age range:> 14 years old
Control channels: 4 channels
Controller Mode: MODE2
Material: ABS
Dimensions and weight
Product Weight: 0.150 kg
Package weight: 0.236 kg
Product size (L x W x H): 22.80 x 22.80 x 3.50 cm / 8.98 x 8.98 x 1.38 inches
Package size (L x W x H): 38.00 x 27.00 x 8.00 cm / 14.96 x 10.63 x 3.15 inches
Package Contents: 1 x Hexacopter, 1 x Transmitter, 1 set of propellers, 1 x USB Cable, 1 x screwdriver 1 x English User Manual
buy in gearbest
Description:
Headless mode:
Lock mode route:
modular structure:
Budget:
- Model: A7 attop
- Gyro: 6-Axis
Material: ABS
ok then when I can upload some pictures, thank you very much
