New Arrival
SYMA X5UW 2.4G Remote Control FPV Quadcopter
http://www.gearbest.com/rc-quadcopters/pp_414566.html
FPV Race Quad Sets GB210, GB190 X-Frame
We released two new FVP Race Quad Sets - both with very nice components
The first one
Frame: Lisam210 / QAV210 Style 3mm Frame
FC: SP3 F3 FC in 6 DOF (Acro) or as 10 DOF (Deluxe) with Mag & Baro
ESC: Little Bee 30a BLHeli ESCs F394 / 2-6S / BLHeli / OneShot125
Motor: Genuine EMAX RS2205 2300 KV
PDB: Matek 3.1 Style PDB 12V, 5V
Props: 5045 BN - now you can use here also Triblade and Quadblade Props
Lipo: Now you can use 4S without any issues
The second one
1000TVL 2.8mm camera specifications:
Ultra mini size
HD 1000TVL camera
2.8mm ultra wide lens
5V power supply
Advanced image sensor, great video quality
Plug and play
PCB board design, light weight, more application ability
Free switch between PAL / NTSC
Video Transmitter specifications:
Manufacturers ID: TS5823
Channel: 40
Transmission frequency: 5.6 - 5.9 GHz
Input voltage: 7 - 24 V
Transmitting power: 600mW
Working current: 190mA 12V
Video bandwidth: 8M
Audio coding: 6.5M
The transmitting end: RP-SMA jack
Antenna terminal: RP-SMA plug
Board color: blue
Dimensions: 38 x 18 x 8 mm ( excluding antenna base )
Net weight: 16g
Ideafly F210 5.8GHz FPV 10CH 2.4GHz Racing Drone
Link:Click here
Main feature:
Streamlined design, standard equidistant axis design
The racer body is made of carbon fiber materials, plus a protective cover motor design
HD camera
The camera has 700TVL horizontal resolution, high-definition night vision lens and high-performance sensors, its photosensitive sensors can automatically adjust according to the brightness of light
Powerful motor design
With brushless motor plus guard landing cushion frame design, the racing drone passed various rigorous reliability tests, which guarantee the racer's high quality and safe flight
One key switch
For more flight fun, you can just press one key to switch into the 3D rollover mode
Ideafly I10 transmitter
Comes with superior I10 transmitter which supports Ideafly F210 to show all high grade movements
DJI 18A ESC
It has multiple protections: Low voltage protection, overheat protection, signal lost protection, etc.
F3 10DOF flight control
F210 series is safe and anti-crash, easy to install and disassemble. With the latest F3 flight system, the professional ESC and 5.8G image transmission, the players set the speed freely according to their needs
The first one
The second one
Ultra mini size
HD 1000TVL camera
5V power supply
Plug and play
Channel: 40
Video bandwidth: 8M
Audio coding: 6.5M
Board color: blue
Net weight: 16g
Link:Click here
Main feature:
HD camera
One key switch
DJI 18A ESC
