FSEARA race#1 Sep. 16,2012 Plant City,FL Indoor RC Complex
#46
im running it
true i have a 13.5 and a 10.5 for indoors
daytona , kissimmee? i have a 5.5 , 6.5, 7.5 will see,
13.5 is more than enough for most of the track in the series. but 10.5 would probably get to the point where cheating is pointless. if limit the mod class to 10.5, I can deal with that. Because we already see couple years back when Me & Mark Burt ran mod in K raceway, We were using 10.5 boosted while Dave Franklin were using 5.5 blinky. the speed were very close.
this will make sure we have the best of both world where wear & tear is minimum.
for the first race in mod, I truly believe 13.5 boosted will probably the fastest setup. So for those that is not ready for mod, you already have a motor ready for this race.
Let the Mod class begin with a soild turn out again.
Thanks everyone.
Thanks everyone.
#48
hmm , on my 411 set up for 13.5 blinky with the same spur i can run a ratio from 4.20 to 8.35 thats plenty of range from a 13.5 to a 5.5 motor. but i use the same software "blinky" on both classes, but i guess i see your point if u are using boost. maybe they will space the races far apart to give you time to change
#51
Tim
#53
state race
Hello Racer's, Just a heads up. 1/12th scale class will be 13.5 boosted, open tire, see everyone in a week. Ron H,
#57
Just curious why 1/12 scale is boosted when the state series is now all blinky?
#58
Regional Moderator
Each track has an option to run a promoter's class. The track director picks the class and sets the rules. Each track may have a different class that is strong in their area and helps get the locals out who might not run otherwise. Ron stated that his class would be 12th scale.
One more week!
One more week!
#59
Regional Moderator
Please make sure your ROAR membership is up to date or budget for renewal at the race. The region director brings the most recent list and I'll have forms to make it as easy as possible.
Please double-check your ESC is blinky enabled or on the list of esc's that aren't timing capable for the spec classes. We don't want any "misunderstandings" regarding ESC setups.
On another note, same for VTA. Check the rules BEFORE the race as we can't start the season making exceptions for equipment.
www.usvta.com
www.usvta.com
