Like Tree60Likes
VBC D10
Old 04-14-2018, 02:46 PM
  #226
Airwave's Avatar
Today I lost the m4 screw and everything with it, the bearings, the spacer, the small conical shim... So as I've mounted D09 arms and hubs in the rear, I've done the same in the front... On asphalt, the c-hubs-based steering is way more efficient than the new one! ISo back to D9.5 for me!
also find the new plastic component very "sandy" compared to the red old one...
Airwave is offline
Old 04-16-2018, 04:31 AM
  #227
Originally Posted by Airwave
What is the difference between VBC and Tamiya ones?
Too many things are diferent, rear width more like it should and camber link positions are shorter, for example the longer one is in between the 2 holes of vbc and shorter is shorter than the shortest possible position vbc ones has.
Originally Posted by vivo quevas
To use Tamiya rear hubs do you have to drill them out to fit the larger pins VBC uses?
yes you do, but it's easy to do. I did it without using any expensive tools.
jorgesimes is offline
Old 04-17-2018, 01:35 PM
  #228
Johnny Wishbone's Avatar
Here is the last setup I used at the ATS race in Edmonton.
http://site.petitrc.com/reglages/vbc...onton20180415/
Johnny Wishbone is offline
Old 04-20-2018, 10:39 AM
  #229
TC5
Hi Airwave ,
Why did you mount the D09 bits in the rear ?
Can you elaborate on the steering difference on asphalt ? I race on asphalt and find the D10 more connected and reactive in terms of steering - also more linear
TC5 is offline
Old 04-20-2018, 12:50 PM
  #230
Airwave's Avatar
In the rear I had no choice, as my rear hubs were defective out-of-the-box (still no news from Tonisport by the way). It seems that some of the first batch were just badly mold and the arm's hole are not perpendicular to the bearings hole. So with that you gat asymmetrical toe-in, which is really a problem on the track (car is stoppen when turning left). So first I use the D09 arms with D09 rear hubs and D10 front knuckles. I ran twice or thrice and finally I lost the M4 screw and with it the bearing, the shims, etc.
So from there I had no other choice than re-install D09 c-Hubs and try. The car was indeed different in the front and absolutely less linear, and it feels better to me, especially in corners entry. It seems that it could be better on small carpet track but on our outdoor track I really prefer the feeling of the D09 :-)
Airwave is offline
Old 04-22-2018, 07:54 AM
  #231
TC5
Default D10 set up sheet
Hi All
Find my set up sheet - for outdoor , a bit bumpy - medium to low grip .
Works well , I used RC3 to get the base and tuned for the track .
I am thinking of going SMJ blue (2.8) in front and Xray 2.6 rear . This to get away from the slight death ring.
The current set up does away with a lot of camber gain and has super rear gent traction and lateral grip - maybe a wee too much
File Type: pdf
TC5 is offline
Old 04-22-2018, 07:56 AM
  #232
TC5
Default Shock Bladders
Hi All ,
I find that the black badders allow the shock to sweat on the D10 . Any feedback ? I was told by some of the ex team drivers to use the xray black bladders or maybe the vbc blue bladders .
TC5 is offline
Old 04-26-2018, 12:43 AM
  #233
Default First time out
Went out with my new d10 at the weekend and have to say it’s quick lots of steering ( think that’s down to the steering was same as when I run a mi5 ) after few changes had a good base setup and could push the faster boys at my track that day
it’s easier to drive then d09 but had trouble with build with arms being to big so ended sanding the edges that face the ff and rr hinge pin blocks to get to drop freely ( I don’t mind fettleing to much plus it’s better then to much slop)
also vbc forgot my alloy chassis but sent it next day with a free car stand worth $17 so can’t complain
really happy with the car
tcboy1983 is offline
Old 04-26-2018, 11:34 PM
  #234
Josh-n-ya's Avatar
Trader Rating: 95 (100%+)
I didn't get a allow chassis with mine either. Might email them tomorrow. I got mine out on the track for the first time this past weekend and had pretty good results. Minor changes and more testing to come.
Josh-n-ya is offline
Old 04-27-2018, 09:13 AM
  #235
Airwave's Avatar
I had a contact with VBC yesterday, they are sending me replacement rear hubs.
Airwave is offline
Old 04-28-2018, 12:23 AM
  #236
I think it is things like this that are stopping vbc taking off in uk ,which Lucas told me in December that they have problems with the company they out source that makes and packages the kits for them . But as a company they are really good at trying to keep customers happy if there is a problem with quick response times
compared to the X-ray 18 which is a good car but I know a few ppl find it had to find a base setup as the setup window is so small , where as the vbc for me from kit all I did was 450cst oil in shocks , 5000 cst oil I diff, screws out the bottom of the chassis and used 2mm chassis brace
am going to try 500cst shock oil as I used 450cst in the old shock so to get the same sort of damper effect I need to change it up a grade or too
Old 04-30-2018, 06:43 AM
  #237
TC5
Originally Posted by TC5
Hi All ,
Bump ...
Hi All - anyone have any feedback ?
TC5 is offline
Old 04-30-2018, 08:23 AM
  #238
What email address did you use to contact them for kit parts issues? is it just [email protected]? This is the only email address I can find on their website under "find dealers"
)EIB( is offline
Old 04-30-2018, 09:03 AM
  #239
Airwave's Avatar
Hi All
I'm sorry but how can a setup sheet be relevant without the tyres or the sauce specified?
Airwave is offline
Old 05-01-2018, 10:09 AM
  #240
try [email protected] same as on invoice
