New Rocket F1 Chassis >
Like Tree15Likes
Old 09-06-2017, 12:33 AM
  #16
Ph3nyx's Avatar
Nice and original Layout !
I added it to RCF1 RCF1.fr - Prototype Rocket F1
Ph3nyx is offline
Old 09-06-2017, 01:53 AM
  #17
luppix's Avatar
thanks!
luppix is offline
Old 09-09-2017, 04:33 PM
  #18
Airwave's Avatar
Nice, it is a very elegant solution. Now you can control the different movement of the pod and add limitations...
I'm pretty sure it will work well on high grip, have you already tried on low grip?
luppix likes this.
Airwave is offline
Old 09-09-2017, 07:17 PM
  #19
GT CRUSING's Avatar
Interesting design, I like how the droop screws are in the upper arms, but my concern would be that those screws are in that location would would be prone to fatigue the part after a large cycle count. Especially since the arms take lots of load. One idea would be to put the droop screws on the other piece its touching, otherwise, youre going to get alot of upper arm failures with the material crack initation originating from those threads. But anyhow, innovative design, go you guys
luppix likes this.
GT CRUSING is offline
Old 09-15-2017, 07:10 AM
  #20
Airwave's Avatar
Especially as your front arms are too buffy... From my experience, F1 need a lot of Flex in the front...
Airwave is offline
Old 09-17-2017, 03:44 PM
  #21
luppix's Avatar
work very good on low grip...a LOT of Rear traction
luppix is offline
Old 09-17-2017, 03:51 PM
  #22
luppix's Avatar
thanks
for now no problem on upper Arms.
on My personal car I have 1 Year old Arms and its perfect...I'm very Happy!
luppix is offline
Old 09-18-2017, 04:14 AM
  #23
British Menace's Avatar
Sure ... but not flex in the arms themselves! Go to softer springs if you want more suspension movement.
Regards
BM
British Menace is offline
Old 09-19-2017, 04:45 AM
  #24
Airwave's Avatar
Just as in touring cars, springs cannot catch higher frequencies, especially the ones coming from the roughness of the track.
For these ones, you must have flex elsewhere. It could be in the chassis, but here I think it could be interesting to have it in the front arms.
Airwave is offline
Old 09-19-2017, 12:05 PM
  #25
Sorry but that is incorrect.
Flex works ... yes. But it works because it feeds progressive compliance into the car. Progressive spring's will do the exact same.
Think of flex as a crutch making a given chassis and set up, work better then with out the flex.
This is due solely to the road condition's being raced on. Usually bumpy and low traction. The "flex" helps the chassis comply to the road surface while we sill run our restricted movement, hard suspension set up's.
Regards
BM
Old 09-25-2017, 12:23 PM
  #26
Airwave's Avatar
I do not agree... Not from my experience on low grip, as we run without additive on sugared asphalt. But it is not very important.
Where can this kit be purchased from?
Airwave is offline
Old 09-25-2017, 02:49 PM
  #27
luppix's Avatar
PM me...
luppix is offline
