2018 Xray X12 1/12 >
2018 Xray X12 1/12
Like Tree50Likes
2018 Xray X12 1/12
    Hide Wikipost
Old 02-08-2018, 01:13 PM   -   Wikipost
R/C Tech ForumsThread Wiki: 2018 Xray X12 1/12
Last edit by: R Dodge
Welcome to the XRAY X12'18 Thread & Wikipost! Here you will find some useful info, tips and tricks as well as setups that are used by several team drivers. Many of us run the X12'18 on high bite carpet and with most US tracks going to the new black CRC carpet, most setups from here out will be developed for those high bite conditions.
Tips & Tricks:
The latest front-end builds up super nice, especially the US version. Since there are fewer molded parts, we are noticing the US front-end to be more symmetrical and consistent.
As with any 1/12 pan car, a smooth operating suspension is critical to performance. It is recommended to polish your kingpins & hinge pins using a dremel or a drill and some sort of polish (IE Gravity polish or Mothers Aluminum polish will work). If you find that your suspension has a bind, you may look at using a reamer or drillbit to make sure the holes are clear of any flashing or debris. Some reamer sizes to consider having are 3mm and 2mm for the kingpin and the upper hinge pin. Be careful not to remove too much material if you decide to ream your plastics.
When building your pod, it is advised to use any wrench w/ 3mm shafts to help build the pod perfectly square. See photo:
Option Parts to consider:
XRA372012 Composite Front Upper Arm Mount – Right – Graphite
XRA372022 Composite Front Upper Arm Mount – Left – Graphite
XRA372177 Spring 4.75 Coils 3.6x6x0.45mm, C=2.0 - Silver (Soft) (2)
XRA372178
Spring 4.05 Coils 3.6x6x0.45mm, C=2.5 - Black (Soft) (2)
XRA373586 Side Spring C=1.2 - Black (2)
XRA378094 Shock Spring C=2.1 – Black
Recent Setups:
Dodge Snowbirds (High Grip Carpet) Stock
Dodge Stock Wars (High Grip Carpet) Stock
Xavier US Indoor Champs (High Grip Carpet) Stock
Kuenning US Indoor Champs (High Grip Carpet) Mod
Hagberg AOC Yatabe (High Grip Carpet) Mod
Hagberg XRS Italy (High Grip Carpet) Mod
Xavier IIC (Medium-High Grip Carpet) Stock
Print Wikipost
Old 08-29-2017, 10:24 AM
  #46
Originally Posted by Thaan
thanks man,just hop my track is still around for the indoor season
X marksthespot is offline
Old 08-29-2017, 07:39 PM
  #47
silden's Avatar
Originally Posted by Yorick
So now you need to buy 2 to have full season coverage... Smart move
same as before and you save the money for the carbon fiber axels.
The updates, especially for the US edition are really great and cover all the bases for CRC black carpet.
You guys are running the same setup as on the '17?
Denis
silden is offline
Old 08-29-2017, 07:52 PM
  #48
Team EAM
Trader Rating: 79 (100%+)
Kits are in the US. I'll have my shipment on Thursday.
EA
TOM MAR likes this.
EAMotorsports is offline
Old 08-30-2017, 02:54 PM
  #49
Denis
Hi, 1/12 is practically dead in Poland last seasons in Nationals and SW area. I follow X12 and X10 as a prediction for new X1. In F1 setup differs mainly in alu chassis for BC, an oils springs, adjustments but not axles nor front suspension (except brace). Personally for now I use carbon chassis full year. We will se what will come with X1 2018, but X10 have only one common setup.
Yorick is offline
Old 08-31-2017, 07:48 AM
  #50
jason cheng's Avatar
Trader Rating: 86 (100%+)
Time To build
Attached Thumbnails 2018 Xray X12 1/12-img_6795.jpg
flyernemesis likes this.
jason cheng is online now
Old 08-31-2017, 09:44 AM
  #51
JEFFs SC10's Avatar
Trader Rating: 15 (100%+)
EA
I"ll take one Eric, put my name on it.
This is Jeff Kaplan from FB
JEFFs SC10 is offline
Old 08-31-2017, 05:21 PM
  #52
EA
How do I get one or two of them?
Lence is offline
Old 08-31-2017, 05:44 PM
  #53
Team EAM
Ive got them up on my site now.
EA
Old 09-01-2017, 09:33 AM
  #54
Trader Rating: 88 (100%+)
Anyone know when the parts will be available? Thinking about doing a conversion on my '17.
MUDVAYNE is offline
Old 09-01-2017, 05:18 PM
  #55
the chassis is totally different
Old 09-06-2017, 12:08 PM
  #56
JeffofSpace's Avatar
Anyone else building or maybe EA know why such large/wide shims are called for on the rear of the lower arm off the mount? The front shims seem right on (3mm)...why the three 5.3mm for the other? Thanks!!
JeffofSpace is offline
Old 09-06-2017, 12:55 PM
  #57
cpal's Avatar
built mine last night and have same question
cpal is offline
Old 09-06-2017, 07:17 PM
  #58
JEFFs SC10's Avatar
Ride height?
cant wait to get my US kit!
Old 09-06-2017, 08:04 PM
  #59
Ride height?
No...this is coming outward from the block to the arm. The front screw has normal 3mm shims...the aft screw has oversized shims. My guess it puts in a place for tweak to happen in a crash.
Old 09-06-2017, 09:31 PM
  #60
Team EAM
The 5.3 is the Diameter. Its still .5 thick so its the same thickness. Its larger because the hole in the caster block is there and it would just go inside the caster block.
Make sense?
EA
