Mugen MTC1
#1441
After an intense year of testing and racing, Mugen Seiki is excited to announce information about the MTC1 performance conversion kit. All the new parts were used at the Reedy Race of Champions EU, where all 3 prototypes MTC1’s ended up in top 10 of the modified class. The prototype MTC1 was able to log some of the fastest lap times of the entire event!
Testing with the prototype MTC1 on asphalt has also shown great results. Most testing was been done by pro drivers, but we also did testing with hobby customers and the testing displayed great results for drivers of all levels.
The kit includes following parts:
1. New upper deck with pitch control rod. Mugen Seiki’s new pitch control rod system prevents the chassis from bending over the maximum length, as it is fixed from the motor mount to the upper deck. Furthermore the flex of the chassis is not affected from the rod. It improves the acceleration significantly especially on carpet or high grip conditions.
2. New C-Hub front suspension. After intense testing we found out that the C-Hub suspension system, in combination with a different wheel axle position, is much easier to drive then the original design.
3. New shock/differential O-Rings: The new softer O-Rings providing less friction and both shocks and differential are working more smooth. This makes the car easier to drive especially on bumpy tracks or tracks with curbs or dots.
4. New differential gears. The new material of differential gears provides increased durability and smoother operation. This will also allow you to do more running between rebuilds.
5. Aluminium spool outdrives. The aluminium outdrives increase the durability of the outdrives. Simply change the composite blades from time to time for increased durability.
All in all, the MTC1 performance kit improves the car durability and performance significantly, and makes the MTC1 highly competitive in the electric touring car class for drivers of all levels.
Carpet and Asphalt set-up can be found here: Mugen Seiki Home (English)
#1442
Regional Moderator
Not really impressed with this "conversion" kit or the name "performance" as ALL it does is change the front to C hub and update the top deck. The rest of the "upgrades" are basically fixes of their mistakes.
They already have fixes for rear diff with the softer orings and new harder gears. They already have optional steel and aluminum front drives. People who care about performance should already bought those parts. They should of released the front hub and top deck the same way, as optional parts, and released an updated kit. Maybe call it MTC1 2019 with all their fixes and upgrade parts.
#1444
#1447
what do you suggest for black carpet? I hear this is a great asphalt car (Mugen duh) but no one uses it around here. It’s really between this and an Xray but I love Mugen cars.
#1450
MTC1 Performance Conversion Set
#1451
While I appreciate that Mugen have released a conversion kit... considering most will already have half of whats in this conversion kit, its not exactly cheap to get some C-hubs, turnbuckles, few alloy bits and a top deck. For me its roughly $160(aud) + post. Wonder if the Items will be sold separately?
#1454
C-Hub Front End Parts List
The parts are sold separately. I was curious if someone could give us a list of the part numbers needed to only do the c-hub conversion. That’s all I need as well.
#1455
1x A2141L - Left C-Hub
1x A2141R - Right C-hub
1x A2143 - C-Hub Bushing
2x A2102 - Rear Alum bulkhead
2x A2121 - Rear Camberlink Mount
1x A2806 - Alum Turnbuckle (28mm)
1x A2810 - Ball link set
1x T2803 - Uniball
1x A2304 - Steering Stopper collar (recommended to use the 5.5 or 6mm)
Also need the following hardware;
For bulkheads camberlink mounts;
4x M3x10 Countersink screw + 4x 2mm shim (for mounting camberlink mount to bulkhead, as per the rear)
2x M3x8 Set screw (for attaching camberlink ball)
For C-Hub
2x M3x8 Button head (lower kingpin)
2x M3x12 set screw (upper kingpin)
And then add other shims for settings as required.
HiH
Ed
