Mugen MTC1
#1561
#1562
Interesting point but I'm pretty sure this is quite irrelevant compare to the change in the mass center position. So it means there is a change in the roll momentum too, so the car rolls more or less in corners...
#1563
is there a tutorial to change fast long mtc1 belt?
#1564
What's everyones current thoughts on this car after the performance kit?
Do you think Mugen will continue and if so are there any rumours of a new kit? I see the standard kit is on sale in a couple places and want to pick one up for a later build.
#1565
I will test my updated MTC1 soon - hopefully this Friday. I'm expecting the car to be as good as my Yokomo BD9 - maybe even better. I have already enjoyed good success with the MTC1 in the original configuration so I'm pretty confident the 2019 version will do very well. Some things I did note about the 2019 performance kit build though.
- Very high quality upgrade kit... even the screws are of great quality (unlike the original kit screws).
- Physically the car seems perfect after the conversion.
- My only concern is the effectiveness of the pitch control rod. It doesn't seem to be very effective at controlling chassis pitch flex so I removed it - this is me flexing the car in my hand with it off vs with it on so I could be out to lunch here... to be clear I'm not talking about twisting the chassis. I'm referring to fore and aft flex when the shock towers take a parallelogram position relative to the chassis while under load.
#1566
#1567
No magic bullet here. Just make a quick note of order of tasks. I e shock tower w/shocks still on it. Diff hold down pieces, top deck, FR hinge block, 1 steering arm ball removal, pull both inner steering arm off their pivots slide assembly to one side, remove spool, remove spur graphite retainer plate, remove spur, and remove / replace belt and reassemble in reverse order. Nothing to it.......RIGHT! Keep the note.😉
#1568
Any more news on mid mount conversion being released, any one with inside information ?
#1569
#1570
Have not heard of mid motor conversion. Have seen a pic of a prototype Robert was trying. I would much rather see a rear active toe kit than a mid motor. 'Course neither one exists.......yet😉
#1571
#1572
#1573
Can change rear toe under suspension compression too increase or decrease depending on what you are looking for.
spec class can run less rear toe to gain staight line speed or mod you can achieve more corner speed.
Some find it a little more inconsistant.
But has it's advantages and disadvantages .
It's good as a fine tuning tool
#1574
What's people thought on chassis for black ETS carpet , will standard carbon work or is alloy the go? What alloy chassis is getting best results .
