Shepherd Velox F1 - customer support
#16
Salut Denis
You should check the central damper , if it's too soft , it could be the problem too
did you checked the tweak ?
#17
Hello Dennis, on my son's car, I reduce the braking dual rate on the transmitter to allow him to brake, but it remains tricky! This helped him however.
#18
Thanks you guys. Braking rate on my transmitter was 60% . I was thinking about a mechanical improvement. I have to drive more to improve my level
#19
P3 for me and my Velox at last French national event !
The car was really great
#22
from now on the kit comes with the optional battery mount, if your kit is a few weeks older you may not have the battery mount in the kit. if so you can contact me and we may find a solution to send you one.
The servo-mount is still an option part.
Greetings.
#23
Due you have a Us Distributor
#24
I am a Driver for TeamC, I am going to be testing it for them. I got the kit yesterday and started the build. So far it is a great build. It did not come with the oring battery hold down. As of right know I don't think there is any distributors in the USA. As far as I know we are the only two (me and my manager) that have them in the USA.
Thank your the reply
Russ
Russ
#26
Hey Grumpybrat,
please see my high-traction carpet setup here:
http://www.team-shepherd.com/pdf/201...nn_Volante.pdf
#28
Hey Russ,
Greetings.
Greetings.
My car was one of the older ones and you said to contact you, I sent a PM to you an have not gotten a response?
Please let me know.
#29
Hey Grumpy,
sorry i didnt saw your PM Message cause my Inbox was full.
Please contact your distributor (Nugget Racing) https://team-shepherdusa.com/
and ask for the
Upgrade Velox F1 battery mount v2 #120011
or
Conversion set 2017 -> 2018 #120012
Greetings
Thilo
and ask for the
or
Greetings
Thilo
